Results 1 to 11 of 11
    Feb 2012
    ft myers florida
    Upper solid mounts for 150 v-6 Mercury
    Looking for two upper solid mounts for 150 V-6 Mercury. I can buy new but this is Low budget build looking for something cheep. Thanks
    Feb 2012
    ft myers florida
    Jul 2012
    Lufkin, Texas
    Bob's will sell you uppers only for $50, they're almost local if you want to save on shipping run by and pick them up...
    Josh Peterson
    Feb 2012
    ft myers florida
ID:	473160Still looking for a cheap set of upper solid mounts. Thanks
    Jul 2012
    Lufkin, Texas
    I fill those exhaust cooling holes that dump in the tuner on those old plates and re drill them behind like the bolt on tuner plates.
    Poor man's dry stack. Not really dry stacked at all but it gets the water out of the exhaust flow!
    Josh Peterson
    Feb 2012
    ft myers florida
    Does not Click image for larger version.
ID:	473178really have a tuner. Old racing stuff ������
    Jul 2012
    Lufkin, Texas
    Damn, it's the old 1750 plate with cast in tuner. Somebody just cut most of the tuner off...
    Josh Peterson
    Feb 2012
    ft myers florida
    Not sure if cut or not. I have only ever seen one other like it?? Was being sold as a t-3 plate but I really don't know. Power head is a 76 I think.
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by 30velocity View Post
    They look like this when unmodified:
    All the plates looked like this from 1976 intro up thru '79, maybe 1980. By 1981 the bolt on tuner was introduced and the exhaust outlets were closed down to the rectangle shape.
    Josh Peterson
    Feb 2012
    ft myers florida
ID:	473206As I said. I don't know. It came off of this. Do you have one of these so we could compare it too? Whatever it is it's a moot point I'm still looking for a pair of solid upper mounts. This Ridgeback can is one of the original first edition because it actually has removable solid lower mounts
    Jul 2012
    Lufkin, Texas
    Those early hi-po motors are a mixed bag! Especially 40+ years later. They've mostly been blown up and/or hot rodded and modified. Being a '76 it's a 2.0? What carbs? The early ridgebacks are cool. No 1 piece plates back then either.
    Hard to find a "deal" on used mounts. $50 from bob's for a new set is a deal to me. If I have any extra used ones they'll be the anodized factory ones and I wouldn't let a pair of those go for $50...
    Josh Peterson
  1. Solid upper motor mounts for OMC V4?
    By rjdubiel in forum General Boating Discussion
    Last Post: 12-14-2015, 06:11 PM
  2. Mercury Solid Mounts Upper
    By Ace in forum Misc. Parts and Accessories
    Last Post: 03-15-2015, 01:16 PM
  3. Mercury Tech: Solid upper mounts - something ain't right here...?
    By gmacrae in forum Technical Discussion
    Last Post: 10-25-2014, 02:37 AM
  4. Solid lower mounts, weak a** rubber upper mounts
    By racer7x in forum Props, Setup, and Rigging
    Last Post: 08-22-2013, 12:36 PM
