Results 31 to 45 of 53
  1. #31
    Sep 2019
    Saint Helena Island, SC
    Shot this video coming back from coffee a few days ago. A lot of wakes, so I never opened it up, ut later in the video I did run it up to about 55mph.
    Clamped the GoPro to the stern light. Next time I’ll get it closer to the engine.
  2. #32
    Houston, TX
    As much setback as you have, I would be real curious about raising your motor up. What's your prop to pad measurement now?
  3. Thanks Reynard38 thanked for this post
  4. #33
    Jul 2004
    Connecticut
    How much setback is that? Easy to experiment by raising the motor up one bolt height given the big diameter of that Bravo prop. Also, still would find a shop with a "power bleeder" if there is one close to you even though you have the hand held unit. Not expensive and checks off that important box.
  5. #34
    ...nice video. boat runs nice too. yeah, if when you go even faster, and its chinewalking a bit, then its mostly cause of your generous setback. but that can be cured, as the boat seems to ride nice the rest of the time.
  6. Thanks Reynard38 thanked for this post
    Likes Reynard38 liked this post
  7. #35
    That a crazy amount of setback for a 24 super.
  8. #36
    ...yes...it is...narrow beam and all...
  9. #37
    Sep 2019
    We had an overcast calmer morning yesterday. Was running 65 on the gps with no chine walk. Playing with the trim. Up a couple bumps, it’d start to wiggle a bit, one click down and it stopped.
    I’ll get some measurements (pad to prop) as well as some pics to show the relationship of motor to hull.
    Thanks everyone for all the help!
  10. #38
    Houston, TX
    That is the PERFECT place to run while learning your boat. One click down and you are back safe. One click up and you start learning! Lol
  11. Thanks Reynard38 thanked for this post
  12. #39
    Houston, TX
  13. #40
    Sep 2017
    Miami
    Looks like you're running the Fleet Master. It appears low in the picture but you'd have to measure your propshaft to pad, you can raise it pretty high, which will help with handling, torque etc. But the Fleet doesn't have the torque tab like the TM. Once you dial in the height, like all the others said, just drive it, learn etc.
  14. Thanks Reynard38 thanked for this post
  15. #41
    Sep 2019
    I got a suction cup mount for the GoPro so next time out I’ll get a close up of the engine leg at speed. The weather hasn’t been great here the last few days.
  16. #42
    Sep 2019
    Was calm coming back from town the other day. Got it up to 72mph on the Garmin.
    Was looking at the engine mount. Looks like I can go 1 hole higher.
  17. #43
    Jul 2004
    Connecticut
    Raise it up one for sure. Did you power purge the steering yet?
  18. #44
    Sep 2019
    Not yet. I did use the bleeder tool I have. Spent some time to get all the air out. Now when I try to move the motor by hand I get maybe 1/4” of movement whereas before it was well over an inch. Made a big difference in steering feel. Much more connected.
    As to the height of the motor I can say that the cavitation plate is slightly above the aft lower edge of the bracket, which is well above the aft edge of the pad. Of course the pad is @ 2’ ahead of the back edge of the bracket.
  19. #45
    PARADISE /Naples
    pictures
  1. Chine walk
    By jeff wilson in forum Racer's Hangout
    Last Post: 07-06-2010, 09:19 AM
  2. chine walk
    By macutty in forum Props, Setup, and Rigging
    Last Post: 12-06-2007, 12:12 PM
  3. Got thru chine walk...now what?
    By tj309 in forum Technical Discussion
    Last Post: 08-22-2007, 01:57 AM
  4. chine walk (help)
    By captain chris in forum Technical Discussion
    Last Post: 06-27-2007, 11:16 PM
  5. Chine walk help
    By Lockjaw in forum Props, Setup, and Rigging
    Last Post: 06-26-2006, 04:08 PM
