Results 16 to 19 of 19
Thread: 300 promax empty oil line?
09-17-2020, 05:26 AM #165000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
So the line stayed full for a few days. Checked it yesterday after a 2 weeks of sitting and it’s empty. No leaks anywhere. It must be back flowing through the pump back into the reservoir I would imagine? I guess this is the point where I pull it out and start pre-mixing. Right? I really don’t want to because pre-mixing with my boat is a pain in the ass
09-17-2020, 10:12 AM #176000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
It may be normal. can u make a drip-loop with a little longer hose, and watch the movement of the oil log/air pocket?
09-17-2020, 10:14 AM #185000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
09-17-2020, 10:42 AM #196000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
maybe the vst fuel level has to drop somewhat, for the oil flow to show? if u cut fuel to the engine, running on vst reserve mix, you should see oil, before engine quits...u think 2-3 min.
300X / 300 Promax fuel supply and return line question
By Mr. Demeanor in forum Technical DiscussionReplies: 13Last Post: 04-02-2018, 08:02 AM -
225 Promax vacuum line portside vst help ...Please
By woundedwarrior in forum Technical DiscussionReplies: 14Last Post: 09-10-2014, 12:33 PM -
1998 2.5 EFI 200 Promax poppet discharge line
By jfw in forum Technical DiscussionReplies: 9Last Post: 07-21-2012, 06:54 AM
