Results 1 to 15 of 19
Thread: 300 promax empty oil line?
09-02-2020, 07:15 PM #15000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Just got back from 4 days at the river. Pulled the cowl off to give it a once over and noticed the line from the oil pump to the vst was empty.... drained the vst and the fuel appeared to have a normal amount of oil. I had ran it wide open for a few miles before putting on the trailer On Monday. Checked compression: 123-125 across the board on a cold motor with plugs pulled and throttle wide open. Cranked it with bleeder screw out of oil pump and oil came out. Pulled check valve going into vst and it seemed to be in working order. Cranked it with throttle(and oil pump lever) wide open and couldn’t get it to pump oil into the line. Pretty sure I didn’t hurt the motor according to the comp readings. Did notice it idled super low the whole trip more towards the end almost wanting to stall which was weird because I put a lower pitch prop on for this trip. Any ideas on what to check?
09-02-2020, 11:06 PM #2
I take it we are talking about an early model ...
Is the oil bag on the side of the motor full ?
If not , check valve on lower starboard side of the block or cracked filler cap on the oil tank in the boat.
If that is good, pull the oil pump out, it has a metal gear. The drive gear on the crank is Bakelite and strips fairly easy . If its bad you'll see grey plastic bits on the oil pump gear , or see debris down inside if you look with a light or borescope.
The good thing is that it lives in it's own little compartment , so the junk will be contained.
Those motors are easy to convert to premix ... unless ya wanna pull the crank ..
09-02-2020, 11:10 PM #35000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Yup the resivoir on the motor is full. I ran for a few days and the remote tank in the boat went down considerably so it’s working/was working. I normally don’t have the kind of luck to where I’d catch a bad pump BEFORE it took out my motor haha that’s why I’m kind of confused. Is there anyway the line could lose its prime?
09-03-2020, 10:38 AM #4
You said , you pulled the bleeder screw and there was oil.
My luck usually runs like that too .. or I get the needle in the haystack type issues that only happen on a full moon, at low tide in months that have 31 days ..
I'm still going with the drive gear ...
09-03-2020, 10:41 AM #55000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
09-03-2020, 01:05 PM #66000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
iF i remember correctly, you can pull a wire, triggering the alarm, to check pump operation, and alarm. just a thought...
09-03-2020, 03:02 PM #7
09-03-2020, 04:33 PM #85000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Do these motors have the same rotational sensor that the 2.5s have?
09-04-2020, 07:43 PM #96000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
isnt there a magnetic flow detector of sorts?
09-04-2020, 07:51 PM #105000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
So I pulled the pump and the shaft looked clean. Turned the pump with a drill motor and it pumped oil like a oil rig. Put it all back together and cranked the motor with my remote starter and it pumped oil. Ran it for 25 minutes on the hose and it smoked like a chimney. What would cause it to lose its prime?
09-04-2020, 07:56 PM #116000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
did you have your mask on, when you removed the cowl.... LOL
09-04-2020, 08:19 PM #125000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
Nope my merc is immune to the rona
09-06-2020, 09:08 AM #136000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
Maybe a heat soak condition could create your oil line air pocket. pwr head cooling down, oil & hoses cooling, expanding, contracting,oil tank pressure.i regret removing my oil inj. stay safe..
09-06-2020, 10:26 AM #145000 RPM
- May 2017
- Ca
- 481
- 11
- 36
- 20
That’s what I’m thinkin. Where our place is at the river it’ll be 115-120° during the day and 70 at night. Go up and down 3k in elevation on the way home. Figured it had to be the engine mounted tank expanding and contracting that cause it.
09-06-2020, 04:10 PM #156000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,530
- 433
- 64
- 435
- 452
yep, another mystery solved. i had a problem with my tank loosing pressure. checked EVERYTHING, clamps,hoses. hit the cap, accidently with a soapy rag,where the lanyard connects, had a ring of bubbles appear. cap looked perfect..lucked out.
300X / 300 Promax fuel supply and return line question
By Mr. Demeanor in forum Technical DiscussionReplies: 13Last Post: 04-02-2018, 08:02 AM -
225 Promax vacuum line portside vst help ...Please
By woundedwarrior in forum Technical DiscussionReplies: 14Last Post: 09-10-2014, 12:33 PM -
1998 2.5 EFI 200 Promax poppet discharge line
By jfw in forum Technical DiscussionReplies: 9Last Post: 07-21-2012, 06:54 AM
