Results 1 to 2 of 2
Thread: Solas Scorpion Prop Changes
08-31-2020, 08:21 PM #15000 RPM
- Jun 2002
- Northern Utah
- 454
- 7
- 24
I've seen several positive posts on the Solas Scorpion S3 prop. I bought a new one this year and it has some differences compared to older versions.
The new version has the variable vent system, not the small vent locating holes. Also, the new version has a 7-1/2" long barrel with a slight flare. The old one has a barrel about 1/2" shorter with no flare.
On the left is a 23" I bought early this year. On the right is a 24" that I've had for a while. They have the same model number on the barrel. I've removed the variable venting on the 23" and fully opened up the 1" holes. I have not run the 24" yet. I'm not sure I will be able to get out of the hole with the tiny vent holes.
It would seem like the shorter non-flared barrel of the older version would be preferred for more bow lift.
Anyway, I hope this helps if anyone is considering purchasing a new or used one.
09-02-2020, 10:20 AM #26000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,529
- 431
- 64
- 434
- 452
I wonder why they felt the need to make that change? maybe help bottom end, be nice to hear some factory comments. i run the short barrel 24, great prop.T he tiny vent holes drill easy, 1/2'' is a good start point
Solas Scorpion prop test
By dnelson964 in forum Props, Setup, and RiggingReplies: 119Last Post: 08-13-2020, 07:14 AM -
WTB Solas Scorpion 25
By Wolfjr in forum Propellers WantedReplies: 0Last Post: 02-10-2019, 07:23 PM -
WTB Solas Scorpion 28
By Finman in forum Propellers WantedReplies: 0Last Post: 11-03-2017, 03:48 AM -
solas scorpion prop on G2 250
By goatmilk66 in forum Props, Setup, and RiggingReplies: 2Last Post: 08-02-2017, 06:30 PM -
Solas Scorpion
By Walleyehed in forum Props, Setup, and RiggingReplies: 17Last Post: 05-27-2016, 02:53 PM
