Results 1 to 15 of 19
    Aug 2020
    lakeland fl
    Unhappy LOW TOP SPEED RPM`S 225 efi
    22 ft Kenner bayboat with a 2001 Mercury 3.0 225 efi with 4 butter flys (boat is only rated for a 200 hp engine) it has never turned over 5000 rpm`s since I purchased boat used a few years ago. It comes out of the hole great and runs perfert to 5000 rps but no higher even with the motor trimmed out. I have now just install chris carson reeds, block stuffers , had chris carson clean and check injectors, dropped down from a four blade 20 pitch to a three blade 19 pitch prop. New fuel filters, new QL77CC plugs, stator and added 300 ecu fuel and 300 ignition modules. Boat still runs the same 5000 max rpm as before the changes. (Engine should turn 6000 plus rpm now due to actually running a under size prop pitch size) HELP !!!!!!
    Aug 2020
    Kingston, Ontario
    Is the speed of the boat different with the two props or is it just that the 19 pitch has less slippage?
    Aug 2020
    lakeland fl
    Speed is a little slower with the 19 pitch my main issue is I cannot get the engine to turn over 5000 rpm`s no matter what I do. With a 19 pitch I should turn over 6000 rpm`s. Just makes no sence.
    Aug 2020
    Kingston, Ontario
    How much hp do you think the motor has?
    How much does your boat weigh loaded?
    How fast are you with both props?
    How fast do you think that you should be going and at what rpm?
    Aug 2020
    Kingston, Ontario
    Compression test? Leak down test?
    Aug 2020
    Kingston, Ontario
    If butterfly open up all the way, look at fuel pressure at WOT and new fuel filters. Injector voltage tests from ECU? Timing? Exhaust restriction?
    Aug 2020
    lakeland fl
    How much hp do you think the motor has? I would have to guess the boat has a min of 250 hp with everything I have done.
    How much does your boat weigh loaded? About 2000 lbs
    How fast do you think that you should be going and at what rpm? I was running about 49 mph at 4900 rpm`s with the 20 pitch 4 blade. With the just added 300 fuel and spark ecu`s , 19 pitch prop, chris carson reeds and block stuffers I only run 44 mph @ 5000 rpm`s.. Rpm`s just wont turn up. My boat is only rated for a max 200 hp engine.
    Aug 2020
    lakeland fl
    Butterflys are open 100% , new filters, I had ecu`s and timing checked by marina, Chris Carson inspected and cleaned injectors The bottom unit was removed and inspected. With the previous 225 ecu`s I was running ran exactly the same. I have had this RPM issue since I bought the boat a few years ago it runs perfect from idle to 5000 rpm`s just wont turn to 5700 - 6000 as need.
    Aug 2020
    Kingston, Ontario
    Compression and leak down?
    Aug 2020
    lakeland fl
    All good, From idle to 5000 rpm I can run with or outrun 99% of
    any boat I cross.
    Oct 2010
    Harrisburg,Pa
    Take a good look at the trigger make sure it's advancing and not hanging up from a wire that's tied too tight and will not allow timing too advanced. Have seen this several times
  12. #12
    Aug 2020
    lakeland fl
    I will check appreciate it.
  13. #13
    Aug 2020
    lakeland fl
    I actually had a marna replace my stator and put a 300 efi fuel ecu and 300 ignition ecu and it still will not turn over 5000 even with a 19 pitch prop.
  14. #14
    Aug 2020
    Kingston, Ontario
    Basic 2 stoke power is going to be air in plus fuel then compression, spark and no leaks then air out. To get most out of it you also need max timing, proper air to fuel and no mechanical problems or gasket leaks etc.
    I don't know the compression numbers or the leak down numbers(asked numerous times) as this will limit the hp.
    Max timing at WOT? you say it has been checked? What is it ?
    Mechanical you say is all ok?
    ECU checked, but all of your issues are at WOT, not sitting on a trailer. Injector drivers in ECU good at 6000 rpm, WOT?
    Strong spark at 5000 rpm, WOT?
    Plugs burning too rich or too lean at WOT? New plugs WOT run, immediate shut down, check plugs for burn.
    Fuel pressure at WOT?
    Temp/water pressure at WOT?
    I think testing on a dyno might help.
  15. #15
    Oct 2017
    Missouri
    Try dielectric grease on the computer plugs
  1. Paddle wheel speed sensors, up to what speed?
    By pcrussell50 in forum Electronics, Audio Systems, and Wiring
    Last Post: 07-28-2019, 07:09 PM
  2. Trim speed and jack plate speed
    By Krazymaan in forum General Boating Discussion
    Last Post: 06-04-2017, 06:40 AM
  3. remooving low speed/high speed spark advence module
    By jmr112 in forum Technical Discussion
    Last Post: 12-14-2016, 10:46 PM
  4. Makita high speed buffer, variable speed
    By BUD in forum Non-Marine Items
    Last Post: 10-10-2015, 01:22 PM
  5. pitch speed versus actual speed
    By FrederickBoater in forum Props, Setup, and Rigging
    Last Post: 11-07-2013, 08:35 AM
