Results 1 to 8 of 8
Thread: 1997 evinrude 225 timing issue
08-23-2020, 09:19 PM #1Member
- May 2009
- Ohio
- 52
Hi guys,
ive got an issue that’s stumping me. I had a stator melt on me 6 months ago and since then I’ve been throwing parts at this motor. It’s got a miss at idle And I’ve lost about 5 mph, My current trouble is in order to get it to idle at a high enough rpm, the timer base has to be about 1.5” Away from the stop. I’ve verified the timing advance, it’s advancing and the full advance is at 16deg.
today I decided to reset everything and do a link and sinc. That put the timer lever back where it has been in the past but it won’t even start.
what am I missing?
Compression is 100-110 on all
new parts(yes I did the throw parts at it thing)
new:
powerpack
stator
timer base
coils
coil wires
plugs
new reed valves
rebuilt carbs ( I’ve checked them 3 times, they are good)
New fuel pump ( replaced the original after 23 years!)
what have I missed?
08-23-2020, 09:25 PM #2Member
- May 2009
- Ohio
- 52
By the way other than a slight miss and lost top end, it runs just fine.
08-23-2020, 09:46 PM #35000 RPM
- Nov 2003
- California
- 191
- 49
- 66
- 29
flywheel....
08-23-2020, 09:50 PM #4Member
- May 2009
- Ohio
- 52
08-29-2020, 06:43 AM #5
08-29-2020, 08:25 AM #6
You replaced everything but the bad unit that would be the voltage regulator
08-29-2020, 08:28 AM #7Member
- May 2009
- Ohio
- 52
09-02-2020, 09:35 AM #8
Since they are water cooled if the block is not full of water it can overheat VR and that can affect charging coils on stator and that in turn can affect the ignition coils. Since your stator melted it would be worth a try, or unhook it and try it, Anytime a stator melts I always replace the VR and most of the time they are blown up.
1997 200 EFI Idling issue
By BullCroaker in forum Technical DiscussionReplies: 25Last Post: 06-30-2020, 10:22 PM -
Timing issue?
By pbxcomm in forum Technical DiscussionReplies: 2Last Post: 06-01-2015, 01:56 PM -
1997 merc 200efi...gauge issue???
By blue wonder in forum Technical DiscussionReplies: 1Last Post: 10-12-2009, 05:15 PM -
2.4 timing issue
By t.martin in forum Technical DiscussionReplies: 6Last Post: 03-31-2009, 03:21 PM -
1997 150 Fishin Motor Bogging Issue
By Talon21 in forum Technical DiscussionReplies: 1Last Post: 06-06-2006, 08:11 AM
