Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 46 to 60 of 81
  1. #46
    long island
    timing advance box is garbage throw it out and set the wot timing. idle timing you do with the motor running at idle
    1978 viper - apricot 2.5 xr6 102.6mph(sold)
    1992 Stv pro comp - structurally restored, mod 200 horn motor 119 so far
    1980 21 shadow project- sold
  2. #47
    May 2020
    My new stator showed up today, probably won’t put it back together until tomorrow. Can someone tell me what ftlbs the flywheel nut should be torqued back on at?
  3. #48
    May 2020
    What is the flywheel nut suppose to be torqued on for this motor? 1985 175hp Mariner.
  4. #49
    Jul 2012
    Lufkin, Texas
    150 ft/lb with red loctite on threads
    Josh Peterson
  5. #50
    May 2020
    Thanks, how about the 4 Allen screws that hold the stator on? I’d imagine they would be inch lbs. but what?
  6. #51
    Jul 2012
    Lufkin, Texas
    Quote Originally Posted by Jmr1974 View Post
    I just put blue loctite on those and get them good and snug...
    Josh Peterson
  7. #52
    May 2020
    Ok, I went and did that. Now the problem is holding the flywheel while trying to torque the nut. Is there any tricks to this short of buying a tool designed for it that I’ll most likely never use again?
  8. #53
    Jul 2012
    Lufkin, Texas
    Yeah, just find a spot probably by the starter where you can jam a big flat head screwdriver straight down into. A cheap square shank one works best. Push the handle over towards the flywheel to jam it into the side of the ring gear. You can usually stop the flywheel enough to torque the bolt. Be careful not to damage anything. It's harder to explain than to do it...
    Josh Peterson
  9. #54
    May 2020
    Just got everything back together with the new stator. Checked for spark and coil/cylinder#3 still had no spark, flipped all 6 coil wires from one stator to the other, I have spark on coil #3 now and no spark on coil#4. My guess is that one of the switch boxes is not working, It’s not giving the green with white wire power depending on which switch box there on either #4 coil has no power or #3 has no power.
  10. #55
    Jul 2012
    Lufkin, Texas
    Change the boxes as a pair. Don't use the Chinese ones off ebay. Merc, Sierra, or CDI are the good ones. Stay away from the blue CDI "race" ones, just the regular black ones.
    Josh Peterson
  11. #56
    May 2020
    Just like the stator, everybody and their brother offers cdi switch boxes anywhere from $150 for a single box to $89 for a pair. eBay has a pair of the cdi brand that claim to be the replacement I need for $114, does this seem like the correct price for 2 of them?
  12. #57
    Jul 2012
    Lufkin, Texas
    No, "CDI Electronics" the name brand not CDI "capacitive discharge ignition." Name brand boxes are closer to $150 each list, not $100/pair...
    Josh Peterson
  13. #58
    Sep 2017
    Ashland city tn
    Yes dont gamble with the boxes. Bought the 2 for 120 once and 1 was bad out of the box
  14. #59
    May 2020
ID:	473281 How about these?
  15. Likes nitro_rat liked this post
  16. #60
    May 2020
ID:	473287 Or these from boats.net for $274 a piece.ouch!
  1. Mercury Tech: latest issue...95 200 Xri EFI sudden random bog
    By 87gtNOS in forum Technical Discussion
    Last Post: 05-09-2016, 10:54 AM
  2. Sudden loss of control box power
    By HighOctane in forum Technical Discussion
    Last Post: 10-07-2014, 07:46 PM
  3. Sudden compression drop in #4 cyl
    By 71V153 in forum Technical Discussion
    Last Post: 06-25-2013, 07:07 PM
