Results 16 to 30 of 81
08-29-2020, 06:29 PM #165000 RPM
- Aug 2020
- Kingston, Ontario
- 83
- 14
Black boxes have proprietary circuitry in them and are not worth trying to figure out if they have failed or exactly how. Discard them and move on as suggested. You can find testing procedures in the service manual, but them are not serviceable if they have failed and not worth the effort IMO.
08-29-2020, 07:35 PM #17Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
heads up this is 2.0 liter 16 amp charging system mota not 40 amp system there are some differences i would think from my experiences after rebuilding mercury motors for a very long time its the stator high side went down
rgsauger liked this post
08-29-2020, 07:45 PM #185000 RPM
- Aug 2020
- Kingston, Ontario
- 83
- 14
I didn't catch that this was a 2.0 liter 16 amp charging system, but the pics do show switch boxes. Maybe check the high rpm coils with a DVM at least for continuity and resistance until you get a DVA adapter for dynamic testing. Maybe worth following TEXAS's hunch.
08-29-2020, 07:58 PM #195000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
You guys got my head spinning now. When it comes to anything electrical I’m in trouble! I just ordered a DVA adapter from amazon along with a flywheel puller if I have to pull it to replace the stator. I should have this stuff next week. Hopefully its not as complicated as it sounds. Will I be able to test these things without pulling the flywheel?
08-29-2020, 08:00 PM #205000 RPM
- Aug 2020
- Kingston, Ontario
- 83
- 14
short answer is yes
08-29-2020, 10:10 PM #21
One of them is timing advance and the other is an idle stabilizer. Both are crap and cause more problems than anything. Check this link.
Your motor will run better without them.
https://www.google.com/search?q=1995...obile&ie=UTF-81990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
08-30-2020, 05:02 AM #22
Pretty sure idle stabilizer and timing advance over is same box. The other box is prob hooked to old oil pump wires or sumthin
09-02-2020, 07:11 PM #235000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
So after further review the wires on the stator are toast, especially the two yellow wires that go to the rectifier. The insulation on them is so brittle It crumbles when I move them around and the wires are green. The flywheel puller tool showed up so I pulled off the flywheel to replace the stator that I need to order. The # on the stator is 398-5454A, when I look for the part online there is always another # after the A... why is that? Can anybody tell me what stator I should order? Also since I’m this far should I go ahead and order a new trigger at the same time? I don’t see and part # on the trigger so I’m not sure what to order for that either... Seems like everyone sells these parts and the prices on them are all over the map. Any recommendations on who has the best price on these items? It’d be nice to buy from one place and be done.
09-02-2020, 07:15 PM #245000 RPM
- Aug 2020
- Kingston, Ontario
- 83
- 14
I just bought some used parts at great prices from bullet123, who has closed shop and selling off all his inventory. He has a thread too. PM him with your needs and he can hook you up and help you out.
09-05-2020, 07:33 AM #255000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Do you happen to know the part# for the replacement stator I need? The stator on my motor is part# 398-5454A. When I look online there’s always another number after the letter A, example 398-5454A12 very confusing. I’d also like to replace the trigger since the wiring is just as old, I can’t figure out the replacement part# for that either. Motor is a carbureted 175hp Mariner serial#6619976.
09-05-2020, 07:37 AM #265000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
09-05-2020, 10:09 AM #27
Box on Top Mark advance module definitely get rid of In The Box on the side is the oil injection module which hooks up to wear your fingers pointing to the module that tells you oil injection Rod is spinning and since you don't have oil injection anymore get rid of all of that. Definitely replace the stator and if the wires are bad on the trigger replace that as well see if that doesn't take care of your spark issue. Because that all needs done anyways just replace it all and check spark
09-05-2020, 10:38 AM #28
One other thing to check is the ground wires to the coils. My 89 175 did the same things some time ago and I found the ground wires had failed. Started with one of them not firing and upon further inspection they were all just about shot. Made up new ground leads and it fixed that problem for me.
09-05-2020, 01:39 PM #295000 RPM
- May 2020
- Wisconsin
- 304
- 7
- 131
Stator is definitely getting replaced, the wires on it are shot. Problem is I can’t figure out exactly what stator I need to order, mine is marked 398-5454A, all the ones online I’m finding have additional numbers after the letter A example 398-5454A12. Mine has nothing after the letter A, 398-5454A nothing more nothing less. This is the only thing holding me up. For now I’m dead in the water.
09-05-2020, 03:37 PM #30
Go to boats.net and put ur serial in and it will give u updated # on sierra and oem, can use that # to get cdi stator (little cheaper) still good quality.
Mercury Tech: latest issue...95 200 Xri EFI sudden random bog
By 87gtNOS in forum Technical DiscussionReplies: 6Last Post: 05-09-2016, 10:54 AM -
Sudden loss of control box power
By HighOctane in forum Technical DiscussionReplies: 5Last Post: 10-07-2014, 07:46 PM -
Sudden compression drop in #4 cyl
By 71V153 in forum Technical DiscussionReplies: 0Last Post: 06-25-2013, 07:07 PM
