Results 1 to 4 of 4
    Feb 2019
    Shawnee Kansas
    need a drive shaft for a 2 hole cle
    like the title says, looking for a 20” shaft for a 92 CLE 2 hole...
    does anyone have one laying around, or know what the part number is? or what might be interchangeable? the original shaft is stainless steel, but i cut it down for a 12” mid... wanting to go back to a 20... thanks in advance!
    Dec 2014
    San Diego
    I have an older 2 hole with the drain on the bullet that had a 25" shaft when i got it. I just had a regular stainless 20" single bearing shaft swapped in.
  3. Thanks skiwi thanked for this post
    Jul 2012
    Lufkin, Texas
    Regular single bearing shaft will fit with a single bearing...
    Jan 2020
    Pinole, Ca
    I have a 20" single bearing shaft out of a CLE, call Jacob (510) 418-4911
    1990 Collins Mirage - 15" 260
    25 hp Merc with dry side pipe
  1. Replies: 6
    Last Post: 04-30-2016, 09:53 PM
  2. OMC Tech: How to cut hole in mid to cut drive shaft??
    By sixmassive in forum Technical Discussion
    Last Post: 11-19-2010, 08:12 PM
