Results 1 to 4 of 4
08-21-2020, 06:04 PM #1Junior Member
- Feb 2019
- Shawnee Kansas
- 26
need a drive shaft for a 2 hole cle
like the title says, looking for a 20” shaft for a 92 CLE 2 hole...
does anyone have one laying around, or know what the part number is? or what might be interchangeable? the original shaft is stainless steel, but i cut it down for a 12” mid... wanting to go back to a 20... thanks in advance!Last edited by All9up; 08-21-2020 at 06:14 PM.
08-23-2020, 06:27 PM #2
I have an older 2 hole with the drain on the bullet that had a 25" shaft when i got it. I just had a regular stainless 20" single bearing shaft swapped in.
skiwi thanked for this post
08-23-2020, 07:07 PM #3
Regular single bearing shaft will fit with a single bearing...
09-01-2020, 08:44 PM #4
I have a 20" single bearing shaft out of a CLE, call Jacob (510) 418-4911
1990 Collins Mirage - 15" 260
25 hp Merc with dry side pipe
CLE parts, Drive shaft Hardened race 20", Prop shaft, 1:87 gears
By Leebone46 in forum Lower UnitsReplies: 6Last Post: 04-30-2016, 09:53 PM -
OMC Tech: How to cut hole in mid to cut drive shaft??
By sixmassive in forum Technical DiscussionReplies: 3Last Post: 11-19-2010, 08:12 PM
