Results 1 to 7 of 7
Thread: Proper propeller
08-21-2020, 02:17 PM #1Member
- Apr 2007
- Fort Worth, TX
- 84
Proper propeller
1985 Ranger 335V with 115 OMC. As stated in previous post, changing from burned up Merc 115 to the OMC. Adding 6 inch jack plate and shallow water anchors. With the additional weight on the stern, what prop would you start with? 3 blade or 4? Bow lift or stern? Need your knowledge for a starting point. Thought I would start at 3" below the pad. Thanks!
08-21-2020, 03:59 PM #2
Shallow water anchors add weight far back and up high, worst possible spot. Get a trolling motor with gps lock if you want to go fast with small power...
08-21-2020, 04:13 PM #3Member
- Apr 2007
- Fort Worth, TX
- 84
Not the motor to go fast, I just want to get the best performance I can with what I have. Not a bad idea though with the TM.
08-21-2020, 05:03 PM #4
No one will b able tell u 3 or 4 blade. That will b a experiment. With omc. I'd say get a raker (3 blade) then a know good 4 blade and test. 4 blade prob give better stern lift. 3 blade prob better bow lift , but custom 4 blade could b the ticket
08-21-2020, 05:19 PM #5
I'll 2nd the Raker. Probably your best starting point.
08-21-2020, 06:06 PM #6Member
- Apr 2007
- Fort Worth, TX
- 84
Nitro, thanks for the suggestion, we decided to go with the TM instead. Works shallow or deep. Now without the added weight, does this change any suggestions. I have an 85 Laser basser with an Evinrude 115 and a 22" Turbo 4 blade. Wish it was a 21, but will probably start with that and see what happens. Ranger is a much much heavier boat though. At least it is a start. I dont know if the Ranger responds to bow or stern lift better.
11-23-2020, 08:20 AM #7New Member
- Oct 2020
- Alaska
Hii.... I'd say get a raker (3 blade) then a know good 4 blade and test. 4 blade prob give better stern lift. 3 blade prob better bow lift , but custom 4 blade could b the ticket
Propeller Case / Propeller Box - Shipping and Storage
By Mr. Demeanor in forum PropellersReplies: 4Last Post: 04-30-2014, 10:15 AM -
Proper hub kit
By indiana jack in forum Props, Setup, and RiggingReplies: 2Last Post: 12-29-2006, 10:11 AM -
What's the proper way?
By BenKeith in forum General Boating DiscussionReplies: 1Last Post: 12-25-2003, 11:31 AM -
What's the proper name
By MarkHP in forum Technical DiscussionReplies: 11Last Post: 09-02-2003, 07:07 PM -
Proper Set Up
By owens repair 52 in forum Props, Setup, and RiggingReplies: 2Last Post: 09-05-2002, 07:26 AM
