Page 1 of 3 1 2 3 LastLast
Results 1 to 15 of 40
    Jul 2010
    Southern Illinois
    1986 Mercury 150 XR2 - RPM Loss at WOT (Dropping Cylinder?)
    Good afternoon,
    I have a 1986 Mercury 150 XR2 S/N: A114812
    This outboard starts fairly easily, idles well, and runs good at low and mid RPM ranges. When I bring it to WOT, it tops out somewhere around 5800 RPM and will run good for a few minutes. However, at some point while running at WOT, you will feel what appears like a miss and then the maximum attainable WOT RPMs drop to around 5000-5200. When this occurs, you can throttle down, drop to idle speed for a few seconds, and then when you take off again the outboard will reach the initial 5800 RPM max.
    Since the problem only occurs at WOT, it's making it a little difficult for me to diagnose. I will be taking the boat back to the lake this weekend and bringing a buddy and my timing light with me so that I can try to find the cylinder dropping out, if I am indeed losing a cylinder.
    • I have replaced all of the fuel lines from tank to outboard. I also replaced the water separating fuel filter.
    • Fuel pump and carburetors were rebuilt last summer. (Link & Sync performed afterwards)
    • Spark plugs have recently been replaced with new NGK BUHW plugs.
    Any ideas on what is occurring would be helpful.
    Thanks!
    Sep 2017
    Ashland city tn
    Stator or switch box trying go out , would b my 1st guess , need test fire on ea cyl while its missing if possible, or pull plugs and c if u have one not firing, also make sure it will jump fire 7/16ths gap , cracked coil magnets possibly
  3. Thanks wcsd106 thanked for this post
    Jul 2010
    Southern Illinois
    Thanks for the reply. I was already planning on taking the timing light to the lake with me on Saturday and having my buddy run is down the water at wot until the miss begins so I can test each cylinder individually.
    Will test the spark at cranking speed tomorrow with a tester set to 7/16 (I've always used 1/2) and visually inspect the coils while I'm in there.
    Houston, TX
    Also check your wires. Mine would drop a cylinder at wot and it was wires
  6. Thanks wcsd106 thanked for this post
    Jul 2010
    Southern Illinois
    Quote Originally Posted by rgsauger View Post
    Plug wires or just the regular wiring?
    Jul 2010
    Southern Illinois
    Quote Originally Posted by Merc 2.5 View Post
    UPDATE 8.21.20: I pulled each spark plug this morning to do a visual inspection and the one to Cylinder #5 is SPOTLESS . The other 5 plugs at least have a little oil / fuel residue on them. My thought is I have probably located my dead cylinder.
    My buddy and I will be taking my boat to the lake tomorrow morning. He's going to run it at WOT while I mess with the timing light. Will be doing 6 runs to verify spark on all cylinders. I have no doubt we should be able to find the dropping cylinder this way.
    Thinking wayyyy outside the box here, but could a blown water jacket cover gasket cause a misfire at WOT?
    Jul 2012
    Lufkin, Texas
    Spotless clean usually means water is washing out the fuel/oil mix. Head gasket more likely, I would think the flow of exhaust down the chest would probably push a small leak out. A leak big enough to kill a cylinder would probably cause water pressure or overheating issues. Anything is possible I guess...
  10. Thanks wcsd106 thanked for this post
    Jul 2010
    Southern Illinois
    That's the thing.. Water pressure is good and the engine isn't overheating. Also, compression is good on all cylinders... within 1 or 2 psi of each other.
  12. Likes nitro_rat liked this post
  13. #9
    Test the #5 coil , check the spark lead thoroughly.
    If one or both are bad go buy 6 fresh.
    Or find a good used coil, swap #5 and take it for a run as usual. But check all your plug leads.
  14. Thanks wcsd106 thanked for this post
  15. #10
    And if you did the plugs prior to the hiccup, maybe someone dropped #5 BUHW on the floor, if you're lucky.
  16. #11
    Jul 2010
    Southern Illinois
    And if you did the plugs prior to the hiccup, maybe someone dropped #3 BUHW on the floor, if you're lucky.
    Unfortunately, no. It was doing this before I changed plugs. I was hoping for a miracle by changing them since the old plugs looked pretty worn.
    Jul 2010
    Southern Illinois
    Update: For what it's worth, Cylinder #5 was the one with the clean plug, not Cylinder #3. I have edited my post above to reflect my error.
    I just performed a resistance check of the #5 Coil per the instructions in the OEM Mercury Service Manual for this outboard. All observed readings were within specified parameters.
  18. #13
    Still rooting for your
  19. Thanks wcsd106 thanked for this post
  20. #14
    Jul 2010
    Southern Illinois
    I'll know more tomorrow once I'm able to hit the water. I'll post an update tomorrow with the results.
  21. #15
    Hope it isn't steam cleaning
  22. Likes nitro_rat liked this post
  1. Mercury Tech: EFI Keeps dropping a cylinder
    By aussiecorey in forum Technical Discussion
    Last Post: 10-15-2018, 05:10 PM
  2. 300 Promax dropping cylinder(s)
    By Mr. Demeanor in forum Technical Discussion
    Last Post: 06-12-2018, 07:19 AM
  3. Pro Max feels like it's dropping a cylinder
    By largecar91 in forum Technical Discussion
    Last Post: 06-27-2017, 08:58 AM
  4. 260 dropping a cylinder down low
    By Bullet 1650 in forum Technical Discussion
    Last Post: 04-06-2005, 05:26 PM
  5. Inline 6 intermittently dropping cylinder
    By cm21 in forum Technical Discussion
    Last Post: 07-26-2004, 04:06 PM
