Page 2 of 2 FirstFirst 1 2
Results 16 to 20 of 20
    Sequim, WA
    Can you post more pics/info about your rig?
    I designed/built a bunch of kneel down boats back in the day and a couple of dinghies for recent cruisers we owned.
    Heres pixs of the last one.
    I think I saw 72 on your video?
    Thats flat freagin flyin for an in-line and even more so on a home made wood boat.
    Way cool dude!
    Thanks! Construction is batten seam, cold molded. Basically longitudinal battens over ring frames, diagonal plywood over the battens and 1/4" planks epoxied to the plywood, with the plank edges aligned with the battens. The design is loosely modeled on a 1937 Century Thunderbolt, but modified for outboard power and the designer (Ken Bassett) incorporated a 12" wide pad into the construction. I don't have many construction photos, but did find photos showing the genesis of the pad, pretty interesting. I was stumped for a while trying to figure out the framing for the pad. Rather than using staples to attach the mahogany bottom and side planks, I vacuum bagged them. No staple holes to fill, but the stress levels when trying to find and seal any air leaks before the epoxy set were almost too much for a first time builder, LOL!
Name:	Boat initial frame up 010 (Large).JPG
ID:	472030Click image for larger version.
Name:	All battens on 003 (Large).JPG
ID:	472031Click image for larger version.
Name:	Hull May 14 2011 011.jpg
ID:	472032Click image for larger version.
Name:	First Vacuum Clamp 005.jpg
ID:	472033Click image for larger version.
Name:	coverboard and king plank on 001 (Large).jpg
    The boat was designed to use a late '80s 60HP Mercury, which is very light compared to the L6 and CMC trim system I have on her now. The boat handles the increased weight well, but under 37mph she does porpoise like crazy. I made a 5 degree wedge out of mahogany attached to the transom, but still not enough negative trim. Not really an issue considering how I typically use the boat. Gauges include water pressure, GPS speedo, tach, voltmeter, fuel, mechanical trim indicator. Hot Foot throttle, Uflex Silver Steer hydro steering.
    14'10" Home Built Mahogany Runabout - Ken Bassett Design
  2. Thanks Instigator thanked for this post
    Likes Instigator, David liked this post
  3. #17
    Quote Originally Posted by peter1708 View Post
    Very good question, I don't know. I'll ping him and try to find out.
    Sounds smooth and healthy
  4. #18
    7 Post(s)
    I’ve infused a few boats but as a helper, not owner.
    Always thought it took balls of steel.
    We were doing a 28’ boat w/55 gallon drone of resin ��
    W/your hop, and no trim, you either set up for no hop, or wide open throttle.
    They make smaller jack plates w/integrated trim.
    Would add prolly 50 lbs to the transom but may be able relocate other weight to compensate.
    What are you running for a prop?
    Through hub 2 blade brass?
    And for a first time effort???
    You sir, hit it out of the park!
    Checkmate 16' 140 Johnson
    Laser 480 (?) 21' w/GT 200
    24' Sonic w/twin 250 Johnsons
  5. Thanks peter1708 thanked for this post
  6. #19
    Jul 2010
    Southern Illinois
    Last run of morning on Lake Crescent. Getting practice with the new Hot Foot, wanted to video the engine to get a feel for how much trim is being used, just a tick under 5 degrees above neutral in this video. Maxed out at 5800 rpm, 24" small eared chopper.
    Boat: 14'10" planked in Mahogany and Maple
    Engine: 1980 140 power head, short shaft, 1.78:1 gears, prop shaft 2.75" below pad
    Awesome run & great looking boat!
    Totally off topic, but what are you using to get the speed / time / distance overlay on your video?
  7. Thanks peter1708 thanked for this post
  8. #20
    Sequim, WA
    Quote Originally Posted by wcsd106 View Post
    I use a Sony Action Cam HDR-AS100 which has a built in GPS sensor. The Sony software extracts and overlays that data automatically when importing file to computer. I think GoPro, Garmin and others have this feature. Pete.
  1. Jet boats built w/o wood stringers ??
    By brocluno in forum Jet Boats, V-Drives and Stern Drives
    Last Post: 05-25-2020, 10:59 PM
  2. Video - home built mahogany boat - vintage IL6 Mercury
    By peter1708 in forum General Boating Discussion
    Last Post: 07-06-2016, 02:18 AM
  3. Can't buy NEW outboard?!?! **Home-Built boat**
    By home made tunnel in forum General Boating Discussion
    Last Post: 12-17-2014, 06:01 PM
  4. 96 780 Polaris two stroke in a home made aluminum boat. Cool Video
    By LaveyT in forum The Scream And Fly Lounge
    Last Post: 03-02-2013, 10:16 AM
  5. pics of boat home built rocket
    By naughtybynature in forum General Boating Discussion
    Last Post: 02-06-2003, 07:07 AM
