Results 1 to 2 of 2
    Apr 2007
    Fort Worth, TX
    advice on jack plate
    Just acquired an 84 Ranger 335V. Merc 115 has a bad #2 and I have a 115 OMC to put on it (convenient). I know this a lead sled, but I would like to put a jack plate on it while making the change. What setback is recommended (if any)? Just want to put a manual plate on because of cost. I welcome your suggestions. Anyone interested in an 83 Merc 115 with a bad #2 hole? It is 90#. Thanks
    Jul 2012
    Lufkin, Texas
    I've never messed with a 335v but Rangers are usually heavy pigs. 6" is probably all your steering cables and rigging will stand as far as setback. With small power (115) all the setback you can get will help lever the bow up. Get a 6" plate. I like the Hydrodynamics Rapid Jack but there are cheaper options out there (Vance is a good cheap plate).
  1. advice on jack plate
    By laserfish in forum Props, Setup, and Rigging
    Last Post: 08-23-2020, 07:27 AM
  2. advice on jack plate
    By laserfish in forum General Boating Discussion
    Last Post: 08-18-2020, 08:41 PM
  3. Hydraulic jack plate vs. Manual Jack Plate
    By 21CheckmateLD in forum Props, Setup, and Rigging
    Last Post: 04-12-2020, 08:45 PM
  4. Manual Jack Plate vs Hydraulic Jack Plate
    By Burchoid in forum Props, Setup, and Rigging
    Last Post: 05-25-2012, 05:00 AM
  5. Triumph owner here seeking advice on jack plate.Can y'all help??
    By geoboom in forum Technical Discussion
    Last Post: 03-19-2011, 11:15 AM
