Results 1 to 8 of 8
    Jul 2015
    rimouski
    bravo 1 vs promax propeller
    anyone can explain me why my propeller promax make my boat more stable at hi speed ``70 mph `` than bravo one . pitch 24 for bravo and 24. 5 promax .
    my boat is pulsar br 24
    Sep 2019
    Lake Keowee, SC
    Quote Originally Posted by rocket427 View Post
    I also have a closed deck Pulsare 2400 with a Bravo FS 24P. What does the Bravo 1 do, chine walk? Does the ProMax 24.5 completely eliminate the chine walk or what type of stability you had? Is the 24.5 ProMax a labbed prop? Did you run both at the same engine height?
    Jul 2015
    rimouski
    the bravo 1 chin walk and porpoise a lot same height. pro max it`s not labbed . promax is better but not perfect i ride faster with promax .
    Sep 2019
    Lake Keowee, SC
    Merci bien, mon ami. How much faster is the Promax? Do you have a 300XS or 300R engine? I have a 300R closed deck with a Bravo FS 24P and some chine walking between 70 - 72 mph. My friend has a BRX with a 300R and violent chine walking at 70 mph.
    Jul 2015
    rimouski
    pro max i touch 78 mph i have a 400r and if it was more stable i will ride 80 mph my boat is 2400 close deck . and have a jack lift atlas
    Jul 2015
    rimouski
    Jul 2015
    rimouski
ID:	472466 and i broke my pro max last couple week
    Sep 2019
    Lake Keowee, SC
    Bonjour encore mon ami, Your jack plate in the picture looks like at least 8" of set back and maybe 10". You can check with some members on the Checkmate forum but porpoising and other handling issues were sometimes caused by too much set back with the 400R which weighs at least 150 lb more than the 300XS or 300R. The 400R has 4"-5" of set back built into the bracket. The blue 400R / BRX that I test drove did not porpoise (but it had trim tabs) and almost no chine walking at 76 - 77 mph. I think the Atlas bracket was about 5" of setback (plus another 4" - 5" built into the motor. However there are some members with 8" of set back on their Atlas jack plates.
  1. Promax Propeller 23”
    By gwlsu in forum Propellers
    Last Post: 02-03-2020, 08:32 PM
  2. promax propeller??
    By hydrohank in forum Props, Setup, and Rigging
    Last Post: 05-25-2018, 05:20 PM
