Results 1 to 13 of 13
Thread: Reeds
08-16-2020, 09:59 AM #15000 RPM
- Dec 2017
- sam rayburn lake...east texas
- 135
- 13
- 7
Reeds
I just took a set of reeds (YELLOW) out thats good reeds top of the line (FIRST PICTURE THIS SET HAS BEEN SQUARE PORTED BUT DID NOT RUN AS WELL AS CARSON SET UP WITH STOCK REED BLOCKS ) .... But ... Put my carson reeds a stuffers back in my 2.5 if you haven't tried them you need to i did have to grind the top of the reed block stands down for clearance its a must to use the stffers but u feel the power change when you crank it hole shot much better and top end power is just amazing you can for sure feel the top end come on strong ... This is a fishing boat cant run it over about 6 grand the boat is so out of control dam old champion
I WOULD LIKE TO TRY THE 1 INCH INTAKE SPACER FROM CCMS BUT I dont think i have 1 in to MOVE CARBS THAT MUCH FORWARD IM RUNNING THE STOCK COWLING AND I GUESS THE SPACER IS MADE FOR FUEL INJECTION anyone no if i can run one are notLast edited by ivlakeman; 08-17-2020 at 05:12 AM.
08-16-2020, 11:58 PM #2
Can you ditch the air box and have room?
08-17-2020, 05:25 AM #35000 RPM
- Dec 2017
- 135
- 13
- 7
STOCK COWLING Yep its been goneAttachment 471754 just not much room to move out 1 inch with a spacer and im running a stock cowling Attachment 471755
08-17-2020, 05:50 AM #4
U should b able to run spacer if u have no air box. I can't get ur pics to work. I run a spacer under stock 2.5 cowl. Are you running a 91 motor?
08-17-2020, 06:57 AM #5
Yes he has a 91 7 petal motor.
Spacer should fit, with that 7 petal setup I'd want the RPM's up, 6k is pretty low...
08-17-2020, 04:59 PM #65000 RPM
- Dec 2017
- 135
- 13
- 7
the wh-20 carb bole will hit the bottom cowl moved that for up and the boat want stand any more rpm at 60-65 its (depending on water and wind) out of control bad chime walking 1.87 gear with 25p four blade furry puts it out of the water and out of control but its a fun ride ....i like fooling around with it ... Just hit 100 hrs on the motor
08-17-2020, 05:14 PM #7
6000 rpm, 1.87 gear, 25 pitch prop, 65 mph is 14% slip. At that low a speed it should be hooked up better. That would bring the rev's down even further. Two ways to go, more prop for higher speed or less prop to get rpms up at low speed...
What does your steering look like? Older Champ should have Teleflex dual racks. Probably needs new cables and the slack adjusted out. If you've already gone hydraulic maybe needs bled. Those old Champs are usually heavy and fly well if you have enough power. Probably just needs work on setup...
08-17-2020, 05:21 PM #8
08-17-2020, 06:49 PM #95000 RPM
- Dec 2017
- 135
- 13
- 7
08-17-2020, 07:10 PM #105000 RPM
- Dec 2017
- 135
- 13
- 7
08-17-2020, 10:18 PM #11
You might have to lose the velocity stacks.
Merc, could you tell a difference with your spacer?1990 Shadow bass boat w/ 2.4 200 Merc. Totally resto'd boat and love it!
08-18-2020, 02:53 AM #125000 RPM
- Dec 2017
- 135
- 13
- 7
good question on the spacer on difference ..... velocity stacks may make more power than the 1 inch spacer
08-18-2020, 05:37 AM #13
I built the motor with the spacer and stuffers, but I can say the spacer gonna give more power than the stacks my new motor won't have a spacer or stuffers tho. Also its correct that u can't run spacer and stacks
is the rubber 4 petal reeds and block better then 5 petal boyseen reeds?
By camaro7081 in forum Technical DiscussionReplies: 18Last Post: 04-05-2022, 05:35 AM -
Mercury Tech: fiber reeds and steel reeds in same motor
By buzmacdowell in forum Technical DiscussionReplies: 4Last Post: 07-09-2011, 10:06 PM -
horizontal reeds v/s vertical reeds?
By david martin in forum Technical DiscussionReplies: 10Last Post: 12-04-2007, 06:09 AM -
BOYESEN REEDS VS LAND & SEA REEDS
By MrCougar in forum Technical DiscussionReplies: 1Last Post: 05-14-2001, 07:08 AM
