Results 1 to 3 of 3
    Feb 2005
    1991 Merc 200 EFI Issues
    I have been working on a friends 200 Merc EFI (Serial Number OF068759). My friend said he can get the boat to start by giving it throttle upon start and prior to getting on plane, he said he had to rev the motor to 3500 rpms in neutral 8-10 times. After that he could get the boat to rev up and get up on plane. The boat is not idling correctly and having a hard time starting. He brought it over and i was thinking the switch boxes or stator and trigger could be bad. It has fresh fuel, did a compression check all six wire about 110 +/- 4, fuel pressure at 35 psi, spark is good in all six cylinders. As i was checking everything out, I disconnected the the 2 brown/black wires on the port side temp sensor and found the TPS sensor was way out of spec. Closed it was at .640 and I adjusted the TPS at .250 when closed. I also checked the manifold temperature sensor. I saw it the impedance move up in down in the shade and hot sun, but have no clue where it should be at. After the TPS was adjusted it fired up and ran smooth with no misfires. He took it strait out to the water and it ran fine. The next morning, same issue, it would not stay started and die about 2-4 seconds after cranking. I'm going to do another check and if the TPS is not holding at .250 when closed, I'm thinking it is bad. The issues is that it is a $600 part now. Another thing i was thinking could it be the ECU? Any thoughts.
    Dec 2001
    A TPS is $600????????
    Feb 2005
    Merc part number 14851T03 - $580
    Took a second look at it yesterday. TPS was not too bad, it was tested at .240 this morning. Was set at .250 last night, looks like TPS is ok. Went and checked the grounds and the air temperature sensor again. Unmounted ECU and checked the hose for the manifold pressure hose. Still holds pressure and gave it a quick clean with carb cleaner. Put it back together and it fired, but would not hold idle until I throttled it a few times. I have a new temp sensor coming in for manifold and port side head. Idle fine on following starts.
    My friend started it today with no issues. We have the manifold temp sensor and port head temp senor coming just to replace them. Hopefully the boat is back to 100%??
  1. Tilt\Trim Issues on a 1991 Mercury XRi
    By JonM in forum Technical Discussion
    Last Post: 06-09-2020, 04:04 PM
  2. ISO 1991, Merc 200 hp
    By buddy stewart in forum Engines Wanted
    Last Post: 10-07-2018, 08:21 PM
  3. 1991 2.5 200 merc
    By Summertop511 in forum Outboard Engines
    Last Post: 06-01-2016, 10:13 AM
  4. OMC Tech: 1991 175 Silverstar Eagle vs. 1991 175 Intruder & FastStrike
    By skimmabird in forum Technical Discussion
    Last Post: 03-13-2014, 07:57 PM
  5. 1991 Mariner EFI 200 Issues
    By Fuli in forum Technical Discussion
    Last Post: 06-29-2012, 06:10 PM
