Results 1 to 15 of 17
08-13-2020, 06:10 PM #1Team Member
- May 2009
- 1,882
- 558
- 77
- 637
- 306
- 6 Post(s)
Stupid newb question about running a tank dry...
If you run a tank dry until it the motor dies, could that create a dangerous lean out and burn a piston?
My recreation boat has two tanks and I want to go kind of far, which means I want to run one dry, so I can have plenty of extra in the other tank. But I don't want to be stupid if there is risk of burning a piston as the first one goes dry.
-Peter"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
and a handful of clunkers
08-13-2020, 07:10 PM #26000 RPM
- Aug 2015
- Southeast
- 1,070
- 134
- 80
- 48
- 615
Somebody with better knowledge will chime in but I've always considered running a 2 stroke out of gas as something to avoid especially if running it high rpm and high load like a boat motor runs. Never have run an outboard out of gas but have on mx bikes and various yard tools. None locked up yet.
STV ProComp w/ 225 Promax
STV Procomp with 280
25 Liberator "The Battleship"
Blazer 650 Pro Tour
pcrussell50 thanked for this post
08-13-2020, 07:39 PM #3The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...not a problem. you go right ahead and run out of gas wherever your sweet little bippy wants to.
08-13-2020, 11:06 PM #4Team Member
- May 2009
- 1,882
- 558
- 77
- 637
- 306
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
08-14-2020, 05:10 AM #5
Not a good idea.. one carb circuits allways gonna run dry first and ur gonna get air as it starts to get low..reason race stuffs uses swirl tanks. Plus You may end up in the water if you are on the pad at wfo..
pcrussell50 thanked for this postpcrussell50, Merc 2.5 liked this post
08-14-2020, 08:14 AM #6The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...joking pc. ...damn if i always forget to put a smilie face at the end, it comes back in my court.
pcrussell50 thanked for this postpcrussell50 liked this post
08-14-2020, 08:27 AM #7Supporting Member
- Apr 2003
- New Smyrna Beach, FL./LOTO
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
You have more then likely run a small motor "lawn mower, weed whip, chainsaw" out of fuel and seen it rev up due to being lean as it draws its last little sip. This is not a happy point for the air/fuel ratio that the motor is designed to maintain. --Switch tanks before its dry so you don't hurt the motor and don't have to re-prime it for another start up.
The other thing to consider is that dirt, water and trash fall to the bottom of the tank--is that really what you want to feed your motor on its last desperate breath?
08-14-2020, 10:46 AM #8Team Member
- May 2009
- 1,882
- 558
- 77
- 637
- 306
- 6 Post(s)
Ok guys, got it. It's a 2.0l 150. Usually cruising between 3000-4000 rpm. I will plan on not running a tank dry. Thanks, all.
__________
the wet:
the dry:
2003 bmw ///M5
08-14-2020, 08:30 PM #9
I hear this a lot but I gotta point out that unless your pickup is some custom deal on a float, you are always picking up off the bottom of the tank, just like a straw in a sippy cup. Still a good idea to keep a tank full to fight condensation, but the first sip and the last sip all come off the bottom of the tank.Don't lick my boat, It makes it sticky!
Another Hitman for the Sunshine Syndicate!!
2011 Seafox Viper
08-14-2020, 08:42 PM #10Supporting Member
- Apr 2003
- 6,644
- 606
- 923
- 1698
- 7151
- 3 Post(s)
Let the tank get down the bottom and everything collects to the point of suction more so then being displaced with a few gallons in the tank. I have seen this first hand with my old diesel "it gets down to the bottom and things don't sound so good". Fill it up, change the filters and back to normal.
08-14-2020, 09:06 PM #11The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...joe, thats what the filters for... anyways, the best reason i've heard so far, for not running a tank dry before switching to the next is...you don't have to reprime everything to get restarted. just plain logical. if your at a cruise rpm, the motor will let you know when its "about" to run out. you immediately shut it down & switch over...and away you go. no damage, no noth'n...
08-15-2020, 10:56 AM #12
Capt.Insane-o, Baker343 liked this post
08-15-2020, 11:22 PM #13Team Member
- May 2009
- 1,882
- 558
- 77
- 637
- 306
- 6 Post(s)
"padded wonder"
__________
the wet:
the dry:
2003 bmw ///M5
tnelsmn liked this post
08-16-2020, 11:52 AM #14The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...i have relatives in boulder city nevada...neat little town... its got some cool history too.
08-16-2020, 12:40 PM #15
Newb 2.5 electronics question
By ShadowFlier in forum Technical DiscussionReplies: 6Last Post: 11-20-2019, 07:34 AM -
Low tech/newb outboard question...
By doc_texoma in forum Technical DiscussionReplies: 2Last Post: 01-27-2014, 03:41 PM -
newb l.u.question
By robsampson in forum Props, Setup, and RiggingReplies: 5Last Post: 10-01-2013, 09:41 PM -
Newb with setup question
By RamAirZ in forum Props, Setup, and RiggingReplies: 1Last Post: 05-01-2012, 02:25 AM -
Stupid question about returning to Slosh tank
By BoatGoFaster in forum Technical DiscussionReplies: 0Last Post: 05-27-2001, 09:47 PM
