Results 1 to 9 of 9
08-13-2020, 09:35 AM #1
V4 Crossflow lower unit interchange
I read that the V4 looper lowers are 15 spline same as the V6. Are these a direct bolt in to a crossflow? If not what do I need to do to swap one in?
08-13-2020, 09:52 AM #2Banned
- Jan 2015
- Wisconsin
- 2,331
- 458
- 343
- 6429
- 5147
- 4 Post(s)
Some of the V-4 loopers are 15 spline, but not all of them. I think most of them were actually 13. I have a 1990 140 V-4 and it is 13.
As far as if they fit a crossflow, sorry, I do not know.
LakeFever thanked for this post
08-13-2020, 10:08 AM #3
Ya me neither Im pretty clueless to parts swapping these OMC's around
08-13-2020, 11:21 AM #4
i've never done it but i think they will swap. You may need to change the upper driveshaft, idk. the bolt pattern of the lower unit to the mid is the same.
08-13-2020, 01:04 PM #5
I did find some info saying similar and there are apparently a lot of different factory configs but apparently on the small spline looper lowers the bolt pattern is the same and the drive shaft is often too long which may need a trim and the stock crossflow shift rod has to be re-used. The larger spline V4 gear case I still have zero clue on compatibility
08-13-2020, 03:02 PM #6Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
It surprises me that the driveshaft would be too long. Yes, the shift rod would have to be used based on the intake you have. I have a curved rod and a striaght rod for two different years...........same motor, different intakes and how the shift rods attach.
08-15-2020, 09:14 AM #7
I cannot remember exactly what year but the drive shafts got longer i think in the late 1980's.
I have run one with the shorter shaft length for a short time on a motor that came with the longer drive shaft but i do not think it would be a good idea for long term usage.
The loopers had a different shift shaft from the crossflows but changing that would make it usable.
Paul V.
1987 Hydrostream Viper - 1973 V4 Evinrude 135 Crossflow "Shiny Motor"
08-15-2020, 09:17 AM #8Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
first year v4 had the v6 lower with special ratio
was before 2 piece driveshafts
yes people use them to get 15 spline shaft and v6 ratios
keefallan liked this post
08-15-2020, 11:00 AM #9
Yamaha Tech: 2.6 lower unit interchange
By bakerfreak in forum Technical DiscussionReplies: 1Last Post: 07-22-2012, 09:09 PM -
Do looper and crossflow V6 lower units interchange?
By Steve2ManyBoats in forum Technical DiscussionReplies: 8Last Post: 07-22-2009, 03:26 PM -
OMC Tech: lower unit interchange ??
By rude power in forum Technical DiscussionReplies: 3Last Post: 06-08-2009, 09:10 PM -
By rude power in forum Technical DiscussionReplies: 8Last Post: 04-06-2009, 08:52 PM -
Lower unit interchange
By indiana jack in forum Technical DiscussionReplies: 1Last Post: 06-26-2006, 07:54 AM
