Results 1 to 6 of 6
    Oct 2017
    Jackson Ga
    Triton TR 21 advice!!
    I recently Bought a 99 Triton TR21 with a Merc 225 EFI. Need some advice on setting it up. I知 seeing all kind of numbers from people on what this set up should run. I started Out with 25 Tempest and not sure at all where the jack plate was.. it was turning to many RPMs. So I traded It for a Croxton 26 Tempest. Right now I知 pretty close to 2.5 below pad.. I was At 3.5 to start with once I put The 26 on. And I致e moved it up to 2.5 now and not noticing any change at all.. same RPM.. Same speed.. same water pressure. Same hole shot. 5800 RPm. 70 mph. Realistically what should this boat be running? I知 running a very light load. Maybe 50 pounds of gear. Half tank of gas and only 3 batteries.
    Sep 2017
    Ashland city tn
    Do u know gear ratio on ur motor?
    Oct 2017
    Jackson Ga
    Feb 2017
    Wixom lake michigan
    Bring it up a little at a time until you loose water pressure or get excessive prop slip. Then Take it back down a bit, should be close. If you run light, it may need more prop
    Sep 2017
    Ashland city tn
    Comes out to 14% slip with 26. If u can get that down some u will get little more but loose rpm, 7-10% is pretty good for average bass boat. Being a croxton prop prob runs more like 27? How much did rpm drop from 25 to the worked 26?
    Oct 2017
    Jackson Ga
    I dropped a couple hundred from the 25 to the 26.. didn’t gain any speed but hole shot improved.
  1. 31 Triton
    By David in forum Propellers
    Last Post: 12-23-2016, 08:06 PM
  2. Triton set up
    By Charliem7 in forum Props, Setup, and Rigging
    Last Post: 07-21-2016, 06:10 AM
  3. Replies: 19
    Last Post: 06-17-2016, 03:12 PM
  4. new triton what now
    By hook setter in forum Posting Questions and Suggestions
    Last Post: 06-10-2007, 01:23 PM
