Results 1 to 3 of 3
Thread: Water temp.
08-10-2020, 11:11 PM #1New Member
- Jul 2020
- Santee ca
Water temp.
I have an 88 200 merc outboard and I need help figuring out the running temp. I have a auto meter marine temp gauge and it’s reading 210-235. Could this be right? I have a good 10-15 psi on water pressure and tell tale is peeing good. Do I need a specific temp sender for this gauge or do I need specific gauge for the sender? I have two wires coming off motor. One on left side that just ties to ground lock and one on right side of motor that ties to ground block and goes to gauge
08-12-2020, 10:29 AM #2
Yes the sender and gauge must be calibrated to each other. Call auto meter and get the proper outboard sender for your gauge
tux974 liked this post
08-17-2020, 10:28 PM #3
Youre probably closers to 140 or so
Mercury Tech: 2.4 chrome bore operating temp/ water routing/where to get temp reading/pressure?
By simplyorange in forum Technical DiscussionReplies: 4Last Post: 09-04-2013, 03:01 PM -
Mercury Tech: Water Temp/Engine Temp Gauges
By FisherBoats in forum Technical DiscussionReplies: 2Last Post: 04-11-2012, 08:29 PM -
Low temp range water temp guage
By TheRickster in forum Technical DiscussionReplies: 3Last Post: 12-14-2008, 04:52 PM -
Temp sensor for OMC - water or head temp?
By STV_Keith in forum Technical DiscussionReplies: 6Last Post: 06-12-2006, 11:45 PM
