Results 1 to 7 of 7
08-10-2020, 08:18 PM #16000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 498
- 198
Lightweight 15-20 lb starting batteries with 45-60 Minute Reserve time
What are your guys using for lightweight race batteries in the 15-20lb range? I need some piece of mind on a good reserve time.
I'm told my Merc I6 battery ignition system probably uses maybe 5-10amps to run the ignition system. The Stator only puts out a max of 9 amps.
I'll also be using this battery in 2.4 & 2.5 Carb or EFI systems with the 16amp Stator. These are race/pleasure boat applications. No other electric loads other than the motor.
I'm looking at the $200 Braille 17lb AGM with 45 Minutes reserve time @25Ah draw. The CA looks good. Oddessy and XS have similar offerings
The $130 15.5lb Oddessy PC 680 has 24 minute reserve @ 25AH and CA looks a little low. The $260 20lb PC 950 has 60 minutes and good CA
The lower cost smaller 20-22lb lead acid stuff seems weak.
I realize my lower current draw will extend the reserve minutes longer. I've done the calculation formulas at these lower amps as I've not been able to find chart or spec data
Hoping to spend no More that $100-$200. Not looking to spend the money on the super trick stuff I see in the OB drag boats the last couple of years.
Let me know what you thinkLast edited by scott reierson; 08-10-2020 at 08:31 PM.
08-10-2020, 09:48 PM #25000 RPM
- Feb 2002
- The great corn desert of Iowa
- 298
- 41
- 200
https://www.amazon.com/Genesis-Hawke.../dp/B0002ILK68 I have had good luck with these batteries. It always has the juice to spin my v4. Light weight, can mount it anywhere and it doesn’t even lose charge over the winter. In eighteen years I only replaced it once after twelve years.
1971 Sidewinder 14 SS w Johnson 90 v-4
1959 Texas Maid Falcon w Mercury Mark 35A
1981 Sylvan Sportster w Johnson 85 v-4
2006 Harris pontoon with a Yamaha 90
1969 Sunfish sailboat
08-11-2020, 12:43 PM #3
Look at group 51/51R. Range from 26 to 28lbs. Lead acid battery will work great with your non-regulated I6 charging system. (Honda Civic battery). Will also work great with your 16 amp charging systems regulated or non-regulated.
Ken Eubanks
Bottom Line, It takes hay to make horsepower
08-11-2020, 12:54 PM #4
The Braille AGM works fine with a regulated charging system. If you go this route, the Braille batteries are manufactured by Deka/East Penn. Any of the same size powersports batteries from AZ/Advance/O'Reilly's that are manufactured in the good old USA are probably made by Deka/East Penn and can save you some dollars.
Ken Eubanks
08-11-2020, 07:44 PM #56000 RPM
- Feb 2011
- HUDSON, FLORIDA
- 1,528
- 433
- 64
- 435
- 452
After researching the pros and cons i went with a lithium. have it for a while now, never touched it since i installed it. has never needed a charge, cranks my 225 like a top. just efi and trim. no other draw. incredible power from 2.5 lbs. so far, so good. 200$.
CI STV thanked for this post
08-12-2020, 02:44 PM #66000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 498
- 198
Thanks Turtleherder. Got the link and took a look. Checking out that option
08-12-2020, 03:06 PM #76000 RPM
- May 2001
- Madison, WI
- 1,147
- 253
- 39
- 498
- 198
Hey KenninSC,
Thanks for the reply. I appreciate it. Have a couple questions...Do you know if my thoughts below are correct.
I forgot about the unregulated charge amp issue. Am I correct in understanding that the SLP (sealed lead batteries) are more tolerant of absorbing a overcharge from the unregulated 9-16 amp stators once they are converted to DC by the rectifier?, and that the AGM's may get overcharged by a sustained unregulated amp input raising the charge voltage to high for to long of a period which is bad for them?
If a AGM gets overcharged voltage, does it have an internal link that cooks and opens up making them no good?
I'm sure I've been told in the past but i did not retain the knowledge
Thanks to all of you for your help. If you prefer PM replies please let me know.
ScottLast edited by scott reierson; 08-12-2020 at 07:54 PM.
Lightweight Batteries
By Rayzor in forum General Boating DiscussionReplies: 13Last Post: 10-21-2011, 02:52 PM -
How many of you use automotive starting batteries?
By Ron V in forum Technical DiscussionReplies: 26Last Post: 12-11-2010, 04:14 PM -
1981 merc v6 200hp, hard time starting, questions...
By workaholic in forum Technical DiscussionReplies: 19Last Post: 09-27-2009, 09:44 AM -
Take a minute a read this through..............
By Capt.Insane-o in forum The Scream And Fly LoungeReplies: 20Last Post: 04-08-2004, 02:47 PM
