Results 1 to 1 of 1
Thread: 300 Promax - Electrical Gremlins
08-10-2020, 11:27 AM #15000 RPM
- Apr 2010
- Indian Lake Ohio
- 330
- 74
I picked up a 1999 Promax 300 that I got mounted and rigged and had some minor issue trying to fire it. The starter would just spin and not engage the flywheel. I had a spare starter so I swapped them out and the same thing happened. I put the battery on the charger for a little bit and still the same thing. I then replaced the starter solenoid and again just the starter spinning and not engaging with the flywheel.
Lastly I lubricated the Bendix and worked it up and down. I got distracted and accidently left it in the engaged position and turned the key. That must have been an electrical overload because now I have absolutely no horn when turning the key or fuel pump starting. I checked the 20 amp fuse about the starter solenoid and it was fine. After this I ran out of time to work on it.
1) What damage did I do or where do I need to look to get power back so I get the horn when turning the key and fuel pump.
2) Not sure if lubricating the Bendix is going to solve this. I have a known good battery I will take next to see if that is the case, any other suggestions?
Thank You!Last edited by Lake rat Skater; 08-10-2020 at 12:26 PM.
1999 Promax 300 complete electrical system and Camshaft
By Dean Dorsey in forum Misc. Parts and AccessoriesReplies: 1Last Post: 11-18-2016, 05:39 PM -
electrical trim gauge 300 promax w/offshore bracket
By demag67 in forum Technical DiscussionReplies: 4Last Post: 05-06-2014, 04:24 AM -
PM300 Skater electrical gremlins...Help!
By waterboy222 in forum Technical DiscussionReplies: 9Last Post: 07-26-2011, 09:55 AM -
90hp Yami sank having some gremlins!Help!
By ErikE in forum Technical DiscussionReplies: 4Last Post: 07-16-2008, 08:52 AM -
225 Promax electrical problems
By badbullet in forum Technical DiscussionReplies: 2Last Post: 03-12-2008, 12:50 PM
