Results 1 to 3 of 3
Thread: 1991-7 pedal 200 efi
08-09-2020, 05:38 PM #15000 RPM
- Mar 2018
- NJ
- 196
- 10
Question,I was hoping if someone can tell me if on 1991 200-7 pedal efi are the cylinder ports and internal any better that a 200 FF block. I know the exhaust chest is restricted plans are to open that up,just trying to get a direction with this motor. I have read people saying it was a early Promax. Thank You for the Help.
08-09-2020, 07:32 PM #2Screaming And Flying!
- Dec 2001
- 9,503
- 270
- 191
- 1975
91 motors......I don't know....About the ports on EFI 91 motors …. but the carb motors had Ehxust port slots.....And big chamber heads......And the old Ex port angle...…. which..... witch on a brooommm...zoom … can be fixed.....The rods are OK but the pistons ….need to be up graded......JMO....you can use the BIG rods in that motor.....but the ones in it will last and not cause HOLES...….I have done 91 motors......SORRY guys..... Trim the Ex port. Whit a grey stone..up....flappy wheel it smmoth……..I think.... ya gotta have done a bunch to know.....cut heads or 2.0 heads.....
08-09-2020, 09:21 PM #3
Yes the 1991 blocks are like the 225pm blocks. it used the skinny bottom guided rods. I bought a carb one new in 1991 for $7500 installed.
XR2001 & XB2002
1991 7 pedal motor
By ivlakeman in forum Outboard EnginesReplies: 7Last Post: 06-09-2020, 04:14 PM -
Mercury 1991 200 2.5 7 pedal ...reed question
By ivlakeman in forum Technical DiscussionReplies: 8Last Post: 05-09-2019, 08:11 PM -
Pair 1991 200 Mercury 7 pedal powerheads
By Charlie M in forum Outboard EnginesReplies: 2Last Post: 01-25-2019, 12:14 PM -
Mercury 2.5 200 1991 7 pedal carb 20" w/CLE lower COMPLETE MOTOR
By Hot Shot Merc in forum Outboard EnginesReplies: 3Last Post: 03-24-2018, 09:12 PM
