Results 1 to 15 of 18
08-09-2020, 01:19 AM #15000 RPM
- Oct 2016
- Northern California
- 144
- 7
Ground Wire/Strap on Lower Bracket
Not exactly sure what it's called, but I am trying to find out what part number I need for a ground wire that is bolted to the port side big nut that inserts into my Lock 'n' Stow bracket. I've checked diagrams on sites like Crowley but can't tell which one is which. I did come across this, though, which looks like it might work, but I can't confirm the application for my 1998 Promax 300. Any help would be appreciated.
http://www.boats.net/product/mercury...hoCFGQQAvD_BwE1998 Viper Coral 201
1998 Mercury Promax 300 with Sportmaster
08-09-2020, 04:45 AM #2Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
I am not a merc guy. You can use that strap if you compare it to your old one. Use the ruler provided to compare sizes with the old strap. And you can always enlarge the smaller hole with a drill bit if necessary. But I am sure someone here will give you the part number needed.
08-09-2020, 11:17 AM #35000 RPM
- Oct 2016
- 144
- 7
Thank you for the tip. I took mine off and measured it, and it looks like the correct part. The outer edge of the large ring on mine broke near where the wire connects to it. The wire is still connected to the broken piece of the ring, and the ring is still a complete circle. Do you think soldering the ring back together would be OK, in the meantime while I order the part?
08-09-2020, 11:31 AM #4Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
If you can get the solder to hold, go for it. If not, make a new one with copper wire and ring terms. Its only temp and it will work just fine.
08-09-2020, 07:15 PM #55000 RPM
- Oct 2016
- 144
- 7
I'm not sure what kind of metal the stock terminal ring is, but when I tried to solder it, when it heated up it only sucked the Flux out of the solder, but never took the solder.
Since the break was at the ring, I still had all the cable length, so I cut the broken piece of the ring off the cable, and crimped on a standard automotive terminal ring I happened to have in my garage. It's almost the exact same size as the original, and fit on the large bolt just fine. But, should I be using a ring made of some particular type of metal for something that will see a lot of water when I take the boat out? If it matters, it's a bass boat that sees mainly freshwater lakes, with periodic trips to brackish water, and when not in use the boat is kept in my garage. If it's OK to use a standard terminal ring in this application, I won't even need to order that cable.
Thanks again.Last edited by Basnova; 08-09-2020 at 07:26 PM.
08-10-2020, 03:27 AM #6Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
THat terminal is stainless. The bottom line is that you can either buy a stainless ring term or not. That automotive will corrode over time.....its got copper in it. I would also get a crimper designated for non insulated crimps if you dont already have one. They make a much better and complete crimp.
08-11-2020, 09:03 AM #7
Doesn't this ground strap only matter if your boat is stored in the water with motor submerged? If stored dry, does it serve a purpose?
08-11-2020, 11:47 AM #85000 RPM
- Jun 2017
- Connecticut
- 263
- 38
- 19
- 33
- 21
Interesting story i had this wire corrode out and all my zincs when checked also corroded to the point of not being in contact. Noticed my entire lower unit (it was an SEI) had aluminum oxide galvanic blisters all under and cracking the paint. Boat sits in saltwater and just the nose tip of the motor contacts the water when trimmed up. Interesting how only the SEI lower blistered and the stock mercury exhaust housing was fine. Mercury must use a higher galvanic potential aluminum and the SEI lower housing became the next sacrificial anode.
Also quickly crimped in a solid copper wire while waiting for the mercury part. Cant use solid wire it will quickly fatigue crack with the turning motion and vibration.
08-11-2020, 03:58 PM #9Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
rgsauger thanked for this post
08-12-2020, 10:17 PM #10
08-13-2020, 02:19 PM #11Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
How long did that take Chaz? Thats a nasty one................
08-17-2020, 08:36 PM #125000 RPM
- Oct 2016
- 144
- 7
08-17-2020, 08:39 PM #135000 RPM
- Oct 2016
- 144
- 7
I, too, thought it only mattered in saltwater, where I heard that two different metals in saltwater automatically form a battery of sorts. Although these days my boat only sees brackish water twice a year at most, and is not stored in any water when not in use, I don't want to take any chances. Am I wrong here?
08-18-2020, 11:08 AM #14
It is an Opti block. They seem to rot worse than carb or EFI models. Not sure if the energy required to run the fuel/air system has anything to do with it or not.
It's not mine, it was plopped on my floor .. fix it .. I did , broken bolts and all ..
08-18-2020, 01:55 PM #15Scream And Fly VIP
- Sep 2011
- maryland
- 1,560
- 262
- 178
- 1709
- 1309
Here's the deal...........stainless and aluminum hate each other. Add water...........problems. They are dissimilar metals. You are gonna have problems. Most people dont realize this..........."its a freshwater motor" Blah, blah,blah..........
It does help that it was a freshwater only motor. But I just removed a powerhead from a midsection. Almost every bolt was seized in the adapter. Galvanic action was the enemy here. I am just making my case of the two metals not liking to be mated together.
Anything you can do to keep that from happening is good.......proper grounds(or jumpers in flexible situations)and even anti seize. I hate to say it, but there is still salt in brackish waters. Not as bad as salt, but still much worse than fresh. I know, I am a brackish guy myself.
There is electrolysis in any water............just an fyi. If your motor is running..........battery hooked up.....etc.........there's stuff going on. Its our job to minimize it.
Mercury Tech: Where does this ground wire go??
By Rider in forum Technical DiscussionReplies: 10Last Post: 06-29-2010, 07:36 AM -
Mercury Tech: Broken ground strap, battery drain?
By SkiSanger84 in forum Technical DiscussionReplies: 1Last Post: 08-17-2009, 09:17 PM -
Where is ground wire for trim sender?
By O/B Dude in forum Technical DiscussionReplies: 3Last Post: 03-12-2003, 12:23 PM -
200 XRi: Where does this ground wire belong?
By pyro in forum Technical DiscussionReplies: 2Last Post: 10-08-2002, 09:35 AM
