Results 1 to 3 of 3
Thread: Prop questions
08-08-2020, 05:20 PM #1New Member
- Jul 2020
- Central Wisconsin
Prop questions
So, I had a 1989 Merc 115 that took a dump on me. My 2 nearest marinas wouldn't work on it. Told me it's not worth the time and effort. I found a 1982 Merc 115 tower of power. The prop on the TOP I think is a 22p prop. The markings are pretty hard to read. I also have 2 perfectly good 17p props from the 1989. I'm wondering if these props will fit on the TOP. I know the pitch will change things. I'd really like to use these props if I can.
Also, does anyone have any suggestions on what I could do with the 1989? I'm thinking of parting it out, but not sure if there is a market for some of that stuff. Any info or suggestions would be greatly appreciated!! Thanks in advance
08-08-2020, 08:25 PM #2Team Member
- Lake Coochiching, Ontario
- 7,766
- 276
- 487
- 1590
- 6 Post(s)
What to do with the 89 115 depends upon what is wrong. I would look further for a mechanic. Props should fit
08-08-2020, 09:51 PM #3New Member
- Jul 2020
- Central Wisconsin
I had the 89 running last spring (fist time for the season). Ran for about 5 min and just stopped. Went to turn the key and nothing. Pulled the plugs and one had metal shavings on it. Could turn the flywheel by hand both ways, but only so far and it would stop.... thinking a bad ring?
Prop Questions
By QuarterHorse in forum Props, Setup, and RiggingReplies: 27Last Post: 12-20-2009, 12:08 AM -
Prop questions
By racecar001 in forum Props, Setup, and RiggingReplies: 24Last Post: 08-01-2009, 12:12 AM -
25 PP Prop questions
By Riverrat0 in forum Props, Setup, and RiggingReplies: 3Last Post: 07-29-2009, 03:19 PM -
Some prop questions
By Techno in forum Technical DiscussionReplies: 7Last Post: 08-14-2004, 08:17 PM -
SRX PROP QUESTIONS
By Scott Tharpe in forum Technical DiscussionReplies: 3Last Post: 05-25-2001, 07:22 PM
