Results 1 to 4 of 4
    Western Pennsylvania
    50hp water peeing issue...
    impeller was replaced by shop and during water test on pontoon I'm purchasing stopped peeing after about 20 minutes of running. shop stated impeller was melted and vanes went into power head. Yep, I purchased since shop quoted $2500+ to dismantle powerhead. I'm going to purchase service manual but until it arrives what is located under this cover? Is this wear water from WP goes into powerhead. Also p-hose is attached to this area.
    Attached Thumbnails Attached Thumbnails IMG_4096.jpg   61799079519__D87E7458-70A6-425D-8FB3-88BB44ACE4B4.jpg
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Oct 2010
    Harrisburg,Pa
    Check the place where the pee hose hooks to the motor block,take the hose off there and see if it will pee from that fitting. If not probe it with a piece of wire. They clog all the time.
  3. Likes Capt.Insane-o liked this post
    Got back to basics and U checked the work that the marine shop rookie did. didn't clean all the old impeller out from the intake side below the plate. Output to power head wasw plugged at tube. connected hose to pipe and engine peed fine. cleaned it out and put 4-5 hours over the weekend.
    Attached Thumbnails Attached Thumbnails IMG_4115.jpg   IMG_4101.jpg   IMG_4100.jpg
    Oct 2010
    Harrisburg,Pa
    Backyard mechanic. Hey Euroski how are you doing I met you at Raystown I have the 23 Eliminator Daytona with twin 2.6 Evinrudes a few years back. And to answer your original question that cover is the water jacket cover for the exhaust housing and no that's not where the water comes up it comes up and in on the bottom of the power head
  1. Yamaha Tech: Yamaha 50hp over heat issue...
    By Euroski in forum Technical Discussion
    Last Post: 08-06-2020, 01:11 PM
  2. 300x not peeing
    By HIMAGAIN in forum Technical Discussion
    Last Post: 06-08-2016, 01:27 PM
  3. Yamaha 50hp crankshaft issue
    By fofiveoh in forum Technical Discussion
    Last Post: 04-29-2015, 01:15 PM
  4. Yamaha 50hp wiring issue
    By riverrat321 in forum Technical Discussion
    Last Post: 12-27-2014, 11:51 PM
  5. No water peeing at idle, wot only 8lbs
    By RUNWME in forum Technical Discussion
    Last Post: 07-08-2003, 02:07 AM
