Results 1 to 6 of 6
08-06-2020, 08:52 PM #1Junior Member
- Jul 2020
- California
- 19
1997 Merc 200 EFI Fuel Pump and Reg. Who has in stock?
Boat is in the shop and was advised that fuel pressure is erratic and should replace both pump replace fuel regulator. Bad part is Merc is on back order on parts and takes weeks to ship. In fact shop is claiming a good 3 weeks before they even see the parts. I asked to provide the part numbers they need so I can search online and what better forum to ask then here. Anyone know who might have them in stock (of course once I get the right part numbers)? OR are they any aftermarket products that are reliable and I can use instead? Hard to wait with fishing season in full bloom
08-07-2020, 08:36 AM #25000 RPM
- Feb 2013
- Northern Cal
- 190
- 18
- 37
Make sure the fuel pump driver in the ECU is working properly before replacing the fuel pump.
It has two speeds for driving fuel pump (low and high to account for fuel demand )
https://www.offshoremarineparts.com/62-14-890.html#product_tabs_additional_tabbed
parts.promarineusa.com/products/M50/1/1/30/250/1225/1Last edited by H2Okie; 08-07-2020 at 08:45 AM.
08-07-2020, 09:51 AM #3Junior Member
- Jul 2020
- California
- 19
08-07-2020, 10:27 AM #4Member
- Jun 2020
- southeast GA
- 95
- 70
- 11
- 10
- 60
look on crowleys marine or mercury performance websites you can look up your motor by year make model and serial no. hope this helps
08-07-2020, 04:53 PM #5Junior Member
- Jul 2020
- California
- 19
Thanks for posting. I've reached out to Chris Carson and he said he would help me over the phone once I pull boat from shop. After talking to Chris and briefed him on what the boat shop said, he said there is no way its the fuel pressure regulator that is causing the erratic fuel pressures. shop says at idle its 50lbs then when given gas it drops to 40 then off the throttle jumps to 50 again causing motor to stall. Im picking up the boat from shop tomorrow and have arrange with Chris to walk me through a fix while on the water. I swear there are no good 2 stroke mechanics out in CA that know the older stuff. Wish Chris was closer to me as I'd drive a long way to have him fix my Merc. I just hope he and I can fix it, as shop had it for 3 weeks and came up with this BS then wait another 3 weeks just to get parts. wow.
08-07-2020, 07:28 PM #6
Mercury Tech: super stock 200 which fuel pump
By rick#17 in forum Technical DiscussionReplies: 3Last Post: 07-20-2008, 11:17 AM -
fuel pressure stock pump VS elec. pump
By fastskeeter in forum Technical DiscussionReplies: 4Last Post: 08-14-2005, 09:03 PM -
max rpm, stock fuel pump
By Steven in forum Technical DiscussionReplies: 3Last Post: 02-06-2004, 10:19 PM -
Electric Fuel pump-vs- stock pump
By B.Mac in forum Technical DiscussionReplies: 29Last Post: 10-11-2001, 03:49 PM
