Results 1 to 9 of 9
08-06-2020, 07:51 PM #1Member
- Jun 2020
- Florida
- 57
- 9
- 29
- 14
Metal oil pump drive gear for Merc 3 liter?
Did Mercury ever make metal drive gears to replace the plastic ones that failed? I'm looking for one for a Mercury 250 Offshore EFI
08-06-2020, 10:01 PM #2
lol no...
08-07-2020, 09:53 AM #3Member
- Jun 2020
- Florida
- 57
- 9
- 29
- 14
powerabout liked this post
08-07-2020, 01:01 PM #4
Merc ain't going to send you sh*t. Just buy a new gear and go off of that. And they are far from a perfect motor. A lot of untapped potential but also a ton of work to get to that potential. But like Chaz says they can be had reasonably..especially motors from cancer water.
08-07-2020, 09:27 PM #5
For the first time ever …………. I disagree with you ..
Muckery will send him a color brochure to all their new 4 stroke line-up and a credit application …
Chaz = thinkin, #5 looks to be active ..
However they won't sell ya #2 , which gets goobered up when ya take it off ..
Good thing Pro-Marine keep's em in stock …
And the way they "drarwd the pitcher" It looks like they don't know O-ring #8 goes in the cup …
Ref # Current
Part NbrDescription Superceded
FromStatus Notes List
PriceOnline
PriceQuan
UsedMy
Order
Quan
1 482-9784A4 CRANKSHAFT 9784T6 SS/NLA $0.00 $0.00 1 1 482-9784A11 CRANKSHAFT ASSEMBLY ACT $2,750.79 $2,463.75 1 2 --NOT SOLD SEPARATE, Wear Sleeve $0.00 $0.00 1 3 30-67923T --BEARING, Ball (LOWER) ACT $90.83 $87.37 1 4 53-67446 --RING ACT $2.90 $2.83 1 5 43-19301 --GEAR ACT $38.67 $37.97 1 6 39-843198T01 --RING 816106 SS/ACT $15.80 $15.41 7 7 28-91800 --KEY, Woodruff ACT $2.23 $2.19 2 8 25-35126 --O-RING, (.859 x .139) ACT $2.30 $2.25 1 9 31-88270A02 --RACE ASSEMBLY 88270A1 SS/ACT $142.08 $130.95 2 10 ----NOT SOLD SEPARATE, Needle Bearing $0.00 $0.00 2 9 8M0113288 RACE ASSEMBLY, Bearing 817001A1 SS/ACT $334.33 $308.13 2 10 --NOT SOLD SEPARATE, Roller $0.00 $0.00 88 11 700-858295T14 PISTON 858295T1 SS/ACT $219.50 $202.30 3 11 700-858294T14 PISTON 858294T1 SS/ACT $218.33 $201.22 3 11 700-878572A2 PISTON ASSEMBLY ACT $180.25 $166.12 AR 11 700-878574A2 PISTON ASSEMBLY ACT $168.50 $155.29 AR 11 700-878571A2 PISTON ASSEMBLY ACT $180.08 $165.97 AR 11 700-878573A2 PISTON ASSEMBLY ACT $178.83 $164.82 AR 12 53-8320811 --LOCK RING ACT $0.90 $0.88 12 13 39-827179A12 --RING SET, Piston, With 12 Common Rings ACT $249.33 $229.79 1 13 39-875252A12 --RING SET, Piston, With 12 Common Rings 826293A12 SS/ACT $427.14 $401.86 AR 13 39-875257A12 --RING SET, Piston, With 12 Common Rings 826297A12 SS/ACT $464.79 $437.28 AR 13 39-858772A12 --RING SET, Piston, With 6 Each Top and Bottom Rings ACT $250.50 $230.87 1 13 39-875252A12 --RING SET, Piston, With 6 Each Top and Bottom Rings ACT $427.14 $401.86 AR 13 39-875257A12 --RING SET, Piston, With 6 Each Top and Bottom Rings ACT $464.79 $437.28 AR 14 ----NOT SOLD SEPARATE, Piston Ring (SECOND) $0.00 $0.00 6 15 647-8M0125869 CONNECTING ROD ASSEMBLY 822373A7 SS/ACT $487.07 $458.24 6 16 10-94320 --SCREW, (.375-24 x 1.250) ACT $10.50 $10.24 12 17 31-844338A01 --BEARING/CAGE KIT 43012A1 SS/ACT $83.25 $80.07 6 18 ----NOT SOLD SEPARATE, Bearing $0.00 $0.00 96 19 12-88263 --THRUST WASHER ACT $11.10 $10.83 12 20 29-88258001 --NEEDLE, Roller Bearing 88258 SS/ACT $0.36 $0.36 204 21 31-816773A2 BEARING ASSEMBLY (UPPER) ACT $224.92 $207.29 1 22 26-859093 --SEAL ACT $28.17 $27.66 1 23 25-823683 O-RING, (1.989 x .070) ACT $2.50 $2.44 1 24 12-33001 WASHER, (.641 x 1.250 x .190) 68229 SS/ACT $9.00 $8.78 1 25 11-42979 NUT, (M16) ACT $3.50 $3.42 1 - 27-814195A93 GASKET SET ACT $192.50 $177.41 1 - 809794R97 POWERHEAD ASSEMBLY 809794A97 SS/NLA $0.00 $0.00 1 - 804799A00 POWERHEAD ASSEMBLY NLA $0.00 $0.00 1 - 804800R00 POWERHEAD ASSEMBLY 804800A00 SS/NLA $0.00 $0.00 1
Copyright © 2020 Mercruiserparts.com. All rights reserved.
Powered by Bam Marine
Empty the recycle bin?close
Ok
X
[TABLE="class: noteTable"]
[TR]
Capt.Insane-o liked this post
08-08-2020, 09:40 PM #6
Stop it, yore going to give Joe something to do
08-09-2020, 02:25 PM #7
Yea , I need to start taking pictures of the four-stroke heads that I weld up . You know , the ones that spring a leak between the water jackets across the deck and into the chamber / intake port / exhaust log / cam chain tunnel .. then need full machining to make them usable again … and sometimes NOT ..
The rot should be a good visual to go along with the sales pitch ..
08-09-2020, 03:04 PM #8Screaming And Flying!
- Dec 2001
- 9,502
- 271
- 191
- 1976
Not that I know anything.... but if the plastic failed,,,,,, maybe the steel wasn't turning smmmooth and easy ….I have seen many Merc failuers……..Chazz…….Have you seen the pos that merc drives the oil pump on the 90/115 4 strokes...?Plastic garbage.....and 2 steel 1/8 +or - pins.....that break...…. hope Merc didn't take any short cuts on the new ones...……..Merc should make the new motors out of old recycled plastic soda /beer cans.....they might be better in the salt water......and lighter......OOPs I just gave away my non patterned idea..... WOOPS...….
08-09-2020, 04:58 PM #9
The upwardly mobile yupsters become offended when their decal package is out of date by a year .. they won't keep one long enough to ever notice the plastic drive failure's.
I didn't like the idea of the later 3.0L using an electric oil pump .. now 18 years later , it's proven to be the only way to fly ..
1995 Mercury 2.5l 175hp crankshaft oil pump drive gear.
By Rider_560 in forum Technical DiscussionReplies: 11Last Post: 09-13-2018, 08:15 PM -
merc 3 liter 250 gear case
By supaspat in forum Lower UnitsReplies: 0Last Post: 05-21-2018, 10:54 PM -
Oil pump drive gear
By wildnphx in forum Technical DiscussionReplies: 3Last Post: 04-05-2017, 03:35 PM -
Pics of 3 liter Merc gear case to OMC
By rude tim in forum Technical DiscussionReplies: 20Last Post: 07-25-2014, 10:00 AM -
Drive gear for 2.4 merc
By Quinten in forum Parts WantedReplies: 3Last Post: 07-08-2013, 06:41 PM
