Results 1 to 7 of 7
Thread: 2.0 Mercury lower crank seal
08-06-2020, 05:11 PM #1
I pulled the power head off the adapter plate in preparation for moving everything to a new clamp and swapping in solid mounts. I don't believe the power head has ever been off.
I found this round spring like piece sitting in the plate under the crank. Is this part of a lower crank seal, or just something left from factory assembly?'78 Hydrostream Viking/'98 225 ProMax
08-06-2020, 05:20 PM #2Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
No string used that I know of. Pull the housing and put 2 new seals in it. If original they are trash by now. It's easy and cheap to do. (if the bolts don't shear)
08-06-2020, 05:27 PM #3
Everything has came apart pretty easy so far thankfully. No broken bolts and nothing stuck.
08-06-2020, 05:41 PM #4Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Put the seals in with red loctite. One facing in and one out. Blue loctite or some aviation sealer on the bolts.
08-06-2020, 05:50 PM #5
Ok, so they're under that black cover. I just found them on an exploded view. I'll pull that off tomorrow. Thanks!
08-06-2020, 10:07 PM #6
Both seals go lips down. This stuff isn't getting any younger
tnelsmn thanked for this postXstreamVking liked this post
08-07-2020, 09:05 AM #7Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Capt is correct. Both seals out. Been a while since I have done one. CRS has set in!
Lower crank seal on v6 merc
By KIRCHNER in forum Technical DiscussionReplies: 13Last Post: 11-29-2019, 10:38 AM -
Lower will not go back on- 2.5 merc- lower crank seal came off
By CircleHook in forum Technical DiscussionReplies: 14Last Post: 09-18-2015, 09:37 AM -
Mercury 3.0L lower crank seal and end cap replacement
By Powmer in forum Technical DiscussionReplies: 4Last Post: 02-19-2012, 09:48 AM -
mercury 2.0 150 lower crank seal replacment
By arctic cat 1000 in forum Technical DiscussionReplies: 1Last Post: 09-19-2010, 04:10 PM
