Results 1 to 10 of 10
    Jun 2020
    Oregon
    Sportmaster water psi guage
    I just purchased a sportmaster lower unit and dont see anywhere to hook up a line for a water psi guage. How do I hook on up to it? Any help would be appreciated.
    Sep 2017
    ontario
    I believe your going to have to tell the forum what powerhead you have and your going to pick it up from there .
    Jun 2020
    Oregon
    Its a 1995 Mercury 225 3.0, I am changing from a 25" mid to a 20" mid and also picked up a sportmaster lower unit, but do not see a place for the hose to hook up for the guage. My stock lower unit had one just forward from the water impellor housing.
    Mar 2011
    Up North
    Off top of block will be a fitting
    Sep 2017
    Ashland city tn
    Like Aggie said. Water pressure comes from motor, top block ,behind flywheel on most mercs
    3.0L blocks have three ports at the base of the block at the very back. Port side is water pressure , center is a wash port / plug , starboard is tell-tale …
  7. Thanks Merc 2.5 thanked for this post
    Aug 2006
    virginia
ID:	471101 red arrow
  9. #8
    Sep 2017
    Ashland city tn
    Should had known the 3.0 was gonna b diff thanks
  11. #10
    Quote Originally Posted by SUNKIST View Post
    Your closing in on it ….
  1. fuel pressure guage vs water pressure guage question
    By BRB in forum Technical Discussion
    Last Post: 08-19-2013, 03:27 PM
  2. water pressure guage
    By Shameless in forum Technical Discussion
    Last Post: 01-28-2009, 07:06 PM
