Results 1 to 1 of 1
Thread: merc 300x issue
08-05-2020, 03:06 AM #15000 RPM
- Mar 2006
- auckland new zealand
- 655
- 9
- 13
merc 300x issue
Dose any one know what the power 1 volts relate to on a 2005 300x i have a horn that sounds and on the ddt says horn fault and keeps counting dose not matter is engine is running or not.
Power 1 volts stay at 5volts the only other thing that seems as it might not be correct is the map sensor with just key on its sitting at 14.1.
XstreamVking liked this post
300x fuel pressure issue
By PGJ475 in forum Technical DiscussionReplies: 7Last Post: 08-26-2015, 05:22 PM -
Mercury 300X starting issue
By Steveatmhz in forum Technical DiscussionReplies: 2Last Post: 05-05-2015, 10:00 PM -
Mercury Tech: 05' 300x stalling issue
By F29DCB in forum Technical DiscussionReplies: 16Last Post: 06-23-2014, 07:23 AM -
Mercury Tech: 300x water pressure issue
By ct20sutphen in forum Technical DiscussionReplies: 5Last Post: 08-11-2011, 12:30 AM -
300x Low on power issue
By Hydrilla Houndawg in forum Technical DiscussionReplies: 17Last Post: 07-20-2008, 09:29 AM
