Results 1 to 15 of 22
    Aug 2012
    United States
    Broken crankshaft
    Not my engine but looking to purchase boat. How does the crankshaft break this way? What is the ball park to rebuild the engine? I do live near Fond Du Lac, WI, and I know there are few people that do this that are Mercury employees too.
    Thanks
    https://wenatchee.craigslist.org/boa...169917526.html
    That is a 13# cast iron flywheel that DONT FLEX.
    gonna need a stator and full powered gasket kit and motels well piston rings along with the crank. Lookn at $100 if you do it all yourself.
    Nov 2003
    Portsmouth VA
    Quote Originally Posted by roadkill636 View Post
    I think you left out a zero��
    18 Talon/2.4 carb SOLD
    26 Deck Boat/250 Merc
    Yep. I sure did.
    Ment $1000 in parts
    Aug 2012
    United States
    I see brand new cranks are $2K. Might be better off getting a rebuilt powerhead or upgrading to a newer engine.
    Someone tried pretty hard to do that.
    Sep 2017
    Ashland city tn
    Quote Originally Posted by dtrumbower View Post
    Just get used crank for 2 or 300$ if the journals r smooth its prob good to go , u can also have a run out done on it to make sure ( cheap)
    ...i see a nice merc v-6 crank desk lamp in your future...
    minocqua, wis
    I would like to know what would cause that
    Dec 2001
    Nut tooo tight….. Ski rope around F/W...…..HeeHee….. Try Many full blasts to pull skiers and a short prop......JMO.... Bet the top main saddle is wallered…..
    minocqua, wis
    I pulled a inline flywheel once with nut installed had a fart ,no thread left yikes dumb azz
  12. #12
    Sep 2017
    Ashland city tn
    So u think it was small prop pullin skiers and such? Wouldnt it had tore the hell out of the inside of the cowl when it came loose?? Wonder if sumone was tryin pull flywheel with the rite tools?
  13. Likes David - WI liked this post
  14. #13
    That doesn't really look like the top of a crankshaft... or I'm just not seeing it correctly.
  15. #14
    ...i think we just got set up...
  16. #15
    Yep It fits that taper really well doesnt it?
  1. Broken 2.5 crankshaft
    By lift2win in forum Parts Wanted
    Last Post: 01-04-2018, 05:41 PM
  2. Mercury Broken Crankshaft
    By bigerk in forum Technical Discussion
    Last Post: 08-07-2007, 06:24 PM
  3. Broken tap
    By Steve Reist in forum Technical Discussion
    Last Post: 06-07-2003, 11:46 AM
  4. broken rod!
    By vishus in forum Technical Discussion
    Last Post: 04-21-2003, 09:20 PM
  5. Broken Crankshaft - 200hp Evinrude XFlow
    By Hooty in forum Technical Discussion
    Last Post: 08-23-2002, 08:16 AM
