Results 1 to 4 of 4
08-03-2020, 03:35 PM #1Member
- Aug 2008
- pa
- 77
Air temp sensor connection Merc 260 efi
Need a little help. My air temp sensor on my intake is not connected. Can someone take a peek at their 260 and let me know what color wires I connect the sensor to, I have a new ecu coming from Brucato and the air flow sensor needs to be hooked up. Thanks guys.
08-03-2020, 04:24 PM #25000 RPM
- Apr 2007
- Big Pine Key, Fl
- 416
- 13
- 21
- 45
- 109
They are tan on the merc,not sure what brucato uses ,,but the connectors should be the same,,,Should only be 2 xtra wires on Brucato ECU that temp sender plugs into....
08-05-2020, 05:21 AM #3Member
- Aug 2008
- pa
- 77
Yes I know the temp wires for Merc are tan but where does the flow sensor tie into the circuit? It doesn’t go directly back to the ecu because there’s no disconnected wires there.
08-05-2020, 09:27 AM #4Member
- Aug 2008
- pa
- 77
I do have one tan with a blue tracer not connected so I’ll call Jolie down at Brucato and ask what two wires on the ACU connect to the air glow. I think that’s the easiest solution ��
Air temp sensor 260 merc
By local103racing in forum Parts WantedReplies: 0Last Post: 04-14-2015, 02:20 PM -
Air temp sensor merc 260
By mizer in forum Technical DiscussionReplies: 2Last Post: 06-28-2014, 07:45 PM
