Results 1 to 6 of 6
    Jun 2010
    Norway
    20" Offshore MID-Section Exhaust ports?
    Hi,
    I'm curious on how the upper exhaust relief ports on a 20" offshore midsection, are connected to the exhaust system. This is for a 2.5L 260hp setup.
    I'm just about to install a 2.5L exhaust adapter on my 20" midsection, and can't see how these ports are connected to the rest of the exhaust system.
    Seems like the exh.adapter flange are covering the ports entirely, and the only way the ports are exposed are through the bolt holes for the steering wing plate.
    How are these intended to be exposed? Are there some midsections that have drilled holes through the exhaust channels from inside of the driveshaft housing?
    I'm attaching some photos of my equipment (*.pdf) and a very simple paint sketch, for illustrating what i'm asking about
    Attached Files Attached Files
    Best regards
    Christian
    Jun 2010
    Norway
    Anyone? This is still a mystery to me
    Best regards
    Christian
    Sep 2017
    Ashland city tn
    Can u post a actual pic?
    Jun 2010
    Norway
    Yeah, I'll attach some photos. But it's pretty hard to get a good look at the points that i'm asking about.
    That's why i tried to illustrate it with some mspaint magic
    Attached Thumbnails Attached Thumbnails IMG_20200729_203403.jpg   IMG_20200729_203540.jpg   IMG_20200729_203449.jpg   IMG_20200729_203425.jpg   IMG_20200729_203418.jpg
    Best regards
    Christian
    Pekin, IL
    No sure a 1 piece plate uses the reliefs. On a 2 piece plate the exhaust is routed thru channels tween the halves.
    Rock
    Team Junk
    Feb 2011
    HUDSON, FLORIDA
    IM with rock on that. im looking at a mid that had a 2pc plate. there are holes in the housing. as you show in the lower right pic. dont see why you couldnt drill holes thru, creating the reliefs.
  1. Replies: 6
    Last Post: 10-15-2015, 06:33 AM
  2. 2.5 Offshore mid, idle/relief exhaust ports?
    By tgreen in forum Technical Discussion
    Last Post: 06-02-2015, 08:27 AM
  3. mercury 2.0L exhaust plate and tuner old school huge ports
    By Cal 47 in forum Misc. Parts and Accessories
    Last Post: 02-17-2015, 11:58 AM
  4. Mercury exhaust ports?
    By 79Tron in forum Technical Discussion
    Last Post: 08-15-2005, 02:20 PM
