Results 1 to 5 of 5
    Western Pennsylvania
    Yamaha 50hp over heat issue...
    I'm looking to buying pontoon with 2004 Yamaha 50hp 2 stroke. Would like to add noticed issue after about 3/4 mile on water, no alarms, only surging engine rpm.
    Owner had impeller replaced because of overheat and no water peeing out. All was ok for about 1 mile when peeing stopped. Shop that did impeller told him if issue returns will need to dismantle powerhead to clean out impeller remains. Estimate was $2500... my question does this sound correct and to what extent does powerhead need to be torn down?
    May even consider finding a 90 or 115hp depending what I can buy it for...
    thanks
    90 21Skater w/300xs - sold
    98 STV Euroski w/280 - sold
    Sep 2017
    Ashland city tn
    They prob talking bout cleaning out exhaust/adapter plate under powerhead, but if it got remotely hot , the complete kit should had been replaced , idk bout a yammy. does it have poppet? If so it should b replaced and stats checked then if it does it again , start checking else where (under ph)
    Been trying to find water flow diagram but so far no luck.
    I'm told it's the same as merc uses but painted black.
    Sep 2017
    Ashland city tn
    "Same as merc" is what I was thinkin but not sure. I'd check poppet 1st. If a piece rubber got thru it went straight to poppet, or maybe sum corrosion has it stuck or head gasket depending on the temp it reached
    Since this is the same as a 50hp merc, anyone have the manual to send photo of water flow?
    BTW, it shows up as a 2005 50TLRD
  1. Welding near stator - heat issue?
    By hq_ in forum Technical Discussion
    Last Post: 05-26-2020, 04:45 PM
  2. Yamaha 50hp crankshaft issue
    By fofiveoh in forum Technical Discussion
    Last Post: 04-29-2015, 01:15 PM
  3. Yamaha 50hp wiring issue
    By riverrat321 in forum Technical Discussion
    Last Post: 12-27-2014, 11:51 PM
  4. OMC Tech: 2000 Johnny 200 heat issue
    By Glasstream15 in forum Technical Discussion
    Last Post: 08-24-2014, 03:11 PM
  5. Yamaha Heat Horn Only At High RPM's?
    By bob richling in forum Technical Discussion
    Last Post: 04-24-2007, 09:28 PM
