Results 1 to 12 of 12
Thread: Prop input?
08-03-2020, 07:24 AM #15000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
Prop input?
1991 Checkmate Pulse 185, 1996 2.5, 200 carb (new to boat), 1.87 lower unit ratio. Current setup, 7.5" of setback, prop center line 3.5" below pad.
26 pitch Tempest Plus, 66.7 mph (GPS) @ 57-5800 RPM.
23 pitch Stainless, older nothing fancy with little to no cupping, 66.2 mph (GPS) @ 6200 RPM.
Motor has heads cut by Chris Carson, Carson Reeds and Stuffers. I didn't want to do too much up front until i knew how motor ran,(all new to me), still has timing module connected.
Next step it to lose the black box and reset timing, will this change any of the above numbers or are they pretty much dictated by the current setup?
I also have an XR6 lower unit, 4-1/4" and a 26 pitch Laser II that i can try, might the smaller diameter prop help?.....that Tempest Plus is a huge wheel.
08-04-2020, 10:37 AM #2Team Member
- Lake Coochiching, Ontario
- 7,756
- 272
- 485
- 1577
- 6 Post(s)
If your XR6 is 4.25” it’s probably 1.78 gears which means your 26 Laser would likely be more pitch then you need.
How does it run? Does it carry the bow or do you need a lot of trim?
You could try a 24 Trophy. Used Trophies can be bought and sold without too much lost.
bbezok thanked for this post
08-04-2020, 10:53 AM #35000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
It is a 4.25", 1993 XR6 so i believe you are correct with the ratio, didn't know if the smaller diameter prop might help.
doesn't need a ton of trim, hard to tell just how much is out of the water but the tail begins to get squirrely in the low 60's and takes a bit of finesse to clam her down before it tops out.
From what I've read, they say these boats like around 12" of setback, if that is true might need to add more. Wonder if i could go up another hole to 2.5 below pad?
08-05-2020, 10:32 AM #4Team Member
- 7,756
- 272
- 485
- 1577
- 6 Post(s)
Do you have water pressure and temp gages?
08-05-2020, 10:42 AM #55000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
yes Sir, have both.
08-05-2020, 08:01 PM #6Team Member
- 7,756
- 272
- 485
- 1577
- 6 Post(s)
Then sure, try up a notch.
08-05-2020, 09:57 PM #7
As David said, Trophy's are work horses.
They usually provide good natural all around lift which allows for less trim and more control.
Trophys have a lot of potential and can usually be modified for different hulls and power.
Mark Croxton can really message a trophyLast edited by Baker343; 08-05-2020 at 10:00 PM.
08-06-2020, 05:55 AM #85000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
Awesome guys, thanks for the input. I'll find a 24 Trophy and see how it responds.
08-06-2020, 06:45 AM #9
What are your goals for the boat to run?
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
08-06-2020, 07:09 AM #105000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
Just like to see MPH lead with a 7......I know it's heavy for an 18.6' boat so not trying break any records, but i'd be thrilled to see 70-72 GPS.
08-09-2020, 03:45 PM #117000 RPM
- Feb 2005
- seattle
- 2,654
- 17
- 33
the 26 tempest is actually a 25. the factory has a mold issue. 24 should be the correct starting point. only issue with a trophy would be transom lift on a light boat.
08-10-2020, 06:15 AM #125000 RPM
- Apr 2018
- Maine/Ma
- 216
- 78
- 10
- 131
- 56
Checkmate lists it at 1100 lbs, so it's not that lite. There is a member on here i saw in a thread that has a Pulse with a Promax, need to ask how his is setup with height and setback if i can find where i saw it, might be some help going forward.
need input for changing sport master prop shaft
By Ajskennels in forum Technical DiscussionReplies: 6Last Post: 03-31-2018, 06:38 PM -
Need Input on 5 blade prop.
By rong56345 in forum General Boating DiscussionReplies: 5Last Post: 12-28-2005, 08:15 PM -
Want prop input 4 2.4L EFI Bridgeport
By cbans in forum Props, Setup, and RiggingReplies: 30Last Post: 07-26-2005, 09:38 PM -
Need Prop input for Rapid Craft Twister
By Father Steve in forum General Boating DiscussionReplies: 6Last Post: 08-30-2003, 11:29 AM
