Results 1 to 7 of 7
    Jun 2009
    Bristol, Connecticut
    Mercury Outboard 3 Ram Power Trim Differences
    So Mercury has the 2 wire power trim and the 3 wire power trim which are both three ram units...
    Which one is the order style? Which one is the newer style?
    When did Mercury make the change?
    Will 80/90/2000s trim units interchange as long as the engine has the correct relays/solenoids?
    In addition to the relay/solenoid differences, where the trim unit motors bolts to can be different. Doesn't seem like the motors can interchange on the unit itself because of the difference.
    You can get a harness to convert a 3 wire to 2 wire.
    Will steering wheel blinker control works with either 2 wire, 3 wire, or the harness to convert 3 wire to 2 wire?
    Anything else I should know?
    Jun 2009
    ...shocking...
    ok?
    Jun 2009
    No 3 ram trim experts out there? I know many run the single rams mostly...
    Houston, TX
    My blinker trim works perfectly on my 90 model 2.4 with 2 wire trim. It bumps the triggers on the solenoid so sees almost no current load
  5. Thanks Aaronhl thanked for this post
    Jul 2012
    Lufkin, Texas
    3 wire is the older style, the third wire is a ground. There's two sets of windings in the motor (one for up, one for down). This setup used a solenoid arrangement. 2 wire is the newer style, uses relays to reverse polarity of the motor for up and down. The units as a whole can be interchanged on a 3 ram clamp. Either one can be wired with a blinker trim switch. I like to use the 2 wire and late model relay harness. If you're clever it will even tuck up inside a clamshell cowl!
  7. Thanks Aaronhl thanked for this post
    Jun 2009
    Thanks for the info guys...So to test a 3 wire off the engine I just need to connected black to ground wither blue or green to positive? I tried doing that but the trim motor didn't work, thinking it's not working
    Sep 2017
    Ashland city tn
    I suck at wiring and testing wiring stuff , but I think u still gotta provide the blue or/and green a hot to test it without the solenoids
  1. The Merc XS1500 and the Mercury 150/1500 consumer outboard differences
    Last Post: 01-11-2024, 12:19 AM
  2. Power Trim Unit for 1978-1979 Mercury Tower of Power
    By 1975ss14 in forum Misc. Parts and Accessories
    Last Post: 10-05-2018, 01:40 PM
