Results 1 to 7 of 7
08-02-2020, 08:30 PM #1
Mercury Outboard 3 Ram Power Trim Differences
So Mercury has the 2 wire power trim and the 3 wire power trim which are both three ram units...
Which one is the order style? Which one is the newer style?
When did Mercury make the change?
Will 80/90/2000s trim units interchange as long as the engine has the correct relays/solenoids?
In addition to the relay/solenoid differences, where the trim unit motors bolts to can be different. Doesn't seem like the motors can interchange on the unit itself because of the difference.
You can get a harness to convert a 3 wire to 2 wire.
Will steering wheel blinker control works with either 2 wire, 3 wire, or the harness to convert 3 wire to 2 wire?
Anything else I should know?
08-02-2020, 09:35 PM #2
08-03-2020, 04:10 PM #3
No 3 ram trim experts out there? I know many run the single rams mostly...
08-03-2020, 09:56 PM #4
My blinker trim works perfectly on my 90 model 2.4 with 2 wire trim. It bumps the triggers on the solenoid so sees almost no current load
Aaronhl thanked for this post
08-03-2020, 10:24 PM #5
3 wire is the older style, the third wire is a ground. There's two sets of windings in the motor (one for up, one for down). This setup used a solenoid arrangement. 2 wire is the newer style, uses relays to reverse polarity of the motor for up and down. The units as a whole can be interchanged on a 3 ram clamp. Either one can be wired with a blinker trim switch. I like to use the 2 wire and late model relay harness. If you're clever it will even tuck up inside a clamshell cowl!
08-07-2020, 11:26 AM #6
Thanks for the info guys...So to test a 3 wire off the engine I just need to connected black to ground wither blue or green to positive? I tried doing that but the trim motor didn't work, thinking it's not working
08-07-2020, 07:32 PM #7
I suck at wiring and testing wiring stuff , but I think u still gotta provide the blue or/and green a hot to test it without the solenoids
The Merc XS1500 and the Mercury 150/1500 consumer outboard differences
By Scream And Fly in forum General Boating DiscussionReplies: 18Last Post: 01-11-2024, 12:19 AM -
Power Trim Unit for 1978-1979 Mercury Tower of Power
By 1975ss14 in forum Misc. Parts and AccessoriesReplies: 1Last Post: 10-05-2018, 01:40 PM
