Results 1 to 15 of 29
Thread: 260 EFI bogging
08-02-2020, 06:23 PM #15000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
260 EFI bogging
I've been having a problem for the last month and a half that I have yet to figure out. My top crank bearing went and put a hole in the front half. Ever since I had it welded it has had this persistant bog. In neutral it will run perfect and the first holeshot is great but everything after that it bogs right down to the point of where it is going to die. At this point I have replaced all of the electronics other than the main engine harness and temp sensor. New sealing rings in the crank, new top bearing, new bleed lines, map sensor fitting cleaned and hose replaced, and swapped ECU with a known good one. I also checked and verified that my front half was still straight after being welded (which it was) but put a different one on to eliminate that. Fuel pressure is correct and staying a consistant 56lbs. Four button box confirms that temp sensor is reading properly. This motor ran perfect before the top bearing went. I have a hard time thinking it could be something electrical but obviously it's possible. There was a groove on the block and front half from one of the screw heads but that has been filled in with JB weld. Any help would be appreciated.
08-03-2020, 07:26 AM #2
Someone Please help here...He's been fighting this for almost 2 months...Changed almost every electrical component to date.
There are some very intelligent Merc experts on this board...maybe someone has a new idea for him to try.
Thanks
Greg"The Flying Clamato"
...This ain't no Party, This ain't no Disco, this ain't no foolin around..."Talking Heads - Life During Wartime"
The G-Train has left the station.
08-03-2020, 08:24 AM #3Member
- Jan 2019
- SC
- 58
Check map sensor
08-03-2020, 11:46 AM #4
Have you run it on the lake with a fuel pressure gauge hooked up?
08-03-2020, 01:24 PM #55000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
Yes fuel pressure is good, gauge reads correctly also.
08-03-2020, 01:45 PM #6
is Fuel pressure is correct and staying a consistent 56lbs correct. thought there only around 40psi? I'm sure someone knows, but away from OB's longtime?
90 21Skater w/300xs - sold
98 STV Euroski w/280 - sold
08-03-2020, 02:02 PM #7
08-03-2020, 02:20 PM #85000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
08-03-2020, 02:47 PM #9
08-03-2020, 06:09 PM #10
Has the tps sensor been checked? Didnt see it mentioned above
08-04-2020, 01:46 AM #11
Well, that is a place to start.
That is not the setup for a 2.5 260. That is the setup for a 2.5 Drag which requires a different fuel curve. Your engine may be running way rich.
If it turns out not to be your only problem, you need to get back to basics instead of swapping parts:
1. Is it fuel related or spark related?
2. What cylinders are affected?
The best way to see that is to buy plenty of spark plugs, put in a fresh set out on the lake when you know the engine will run like crap, make a plug chop and see what the plugs tell you.
__PRESENTMarkus' Performance Boating Links:
08-04-2020, 06:19 AM #125000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
new plugs were put in multiple times, it is getting plenty of fuel, plugs are wet. ECU is set to 101. Compression was checked when warm and it is 120 across. Coils were checked and are functioning properly, to eliminate it I swapped with a good known set anyways and no change. If I’m lucky enough to get it on plane while it’s bogging if I let off the throttle it will catch and run perfect for a split second then go back to bogging bad.
08-04-2020, 06:45 AM #13
It is probably bogging because it is running fat like a hooker on a salary.
08-04-2020, 07:05 AM #145000 RPM
- Apr 2017
- Holland,MI
- 350
- 19
- 16
- 34
08-04-2020, 07:24 AM #15
You need an ECU for a 2.5 260.
As far as I know there isn't one for a 56 psi regulator.
http://www.us1.cc/racingefiecuchips.html
v4 bogging at low end
By delawarerick in forum Technical DiscussionReplies: 14Last Post: 09-19-2018, 06:12 PM -
Mercury Tech: Bogging
By FisherBoats in forum Technical DiscussionReplies: 7Last Post: 07-26-2011, 12:43 PM -
still bogging
By gambler2663 in forum Technical DiscussionReplies: 5Last Post: 06-06-2008, 08:15 PM -
250 EFI bogging
By gambler2663 in forum Technical DiscussionReplies: 2Last Post: 06-01-2008, 06:55 PM -
Bogging xp 150
By Richie R in forum Technical DiscussionReplies: 6Last Post: 08-17-2006, 02:22 PM
