Results 1 to 14 of 14
08-01-2020, 02:11 PM #1Junior Member
- Aug 2018
- Gothenburg, Sweden
- 13
Mercury Laser 220 XRI EFI V6 One dead cylinderbank, no spark
Hi guys,
Yesterday it was my turn to be stranded by the boat ramp with a non start condition. ☹️
When I got home I started some troubleshooting and found out that the right cylinderbank was stone dead. No Spark at anyone of the three cylinders. The engine has run a bit rough from time to time but now it wouldn't even attempt to start at all. If one cyl was without spark it could be a ignition coil but when all three is dead it must be something bigger.
What could cause this issue?
Best regards
Tobias
08-01-2020, 02:58 PM #2
go to cdi electronics website and download their troubleshooting guide. most likely a switch box, there are two. each controls three cylinders. they should be changed in pairs. don't be tempted by the cheap chinese ones on ebay. get good ones from mercury, cdi, or sierra. stay away from the cdi blue "racing" stuff.
Merc 2.5 liked this post
08-02-2020, 02:35 AM #3Junior Member
- Aug 2018
- 13
That seems like a very good possibility, I will try to switch places of these switchpacks and see if the problem moves to the left cylinder bank instead. If so, we can be sure.
Thanks for the advice Nitro_Rat🙂
08-09-2020, 11:08 AM #4Junior Member
- Aug 2018
- 13
Now I'm starting to get worried. The new switchpacks havn't arrived yet so I switched places between the two switchpacks. No difference! The engine still only fires at the left cylinder bank.
What now?
08-09-2020, 11:15 AM #5The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19218
- 3 Post(s)
...if your sure of your diagnosis, cancel the order, since it hasn't been processed...
08-09-2020, 12:51 PM #6Junior Member
- Aug 2018
- 13
08-09-2020, 01:32 PM #7Screaming And Flying!
- Jul 2002
- FT WORTH, TEXAS
- 8,031
- 9
- 146
- 313
- 503
trigger maybe but since its a 220 it must the very early 2.4 laser not a 2.5 mota with those things it could be a lot of stuff ask me i had my vaccination on them
08-09-2020, 03:46 PM #8Junior Member
- Aug 2018
- 13
Correct, it is a 2,4, atleast for all I know. The powerhead has a casting date "94" so I assume it has been swaped sometime during mid 1990's.
It seems like I have to take it step by step, i downloaded a troubleshooting manual so I will try to take it step by step to see if I can narrow it down a bit.
First step will be to unscrew the yellow/black killswitch cable from both switchboxes. Perhaps it can give me the spark back on both sides.
Texas, what kind of Issues has your engine given you?
08-09-2020, 04:27 PM #9
If you switched the switch boxes and all the wires between the 2, sounds like a stator to me.
Merc 2.5, Capt.Insane-o liked this post
08-16-2020, 11:56 AM #10Junior Member
- Aug 2018
- 13
Unfortunatly the the switchpacks havn't arrived yet.. I did a little test today. I switched the Blue/White cables between the switchpacks. Guess what, I now got spark on all three cylinders at the right cylinderbank! The spark is now gone at the entire left cylinderbank.
What conclusion can we draw from from this?
08-16-2020, 12:32 PM #11
The blu/wht wire is a power supply from the stator. Also no 2.4s that I know of after 1990. If your build date is 94 you have either a 2.0 or a 2.5. Post a picture of the powerhead with the cowling off.
Rock
08-16-2020, 02:20 PM #12Junior Member
- Aug 2018
- 13
I will try to get to my boat and take some pictures during the week.
So, if the Blue/White cables are power from the stator, could I make the conclusion that the stator needs to be replaced?
Another thought, would it be possible to put a jumper cable between the Blue/White cables and get the engine to run or will the ignition timing be out of sync then?Last edited by Tobias; 08-16-2020 at 02:21 PM. Reason: None
08-16-2020, 02:54 PM #13
08-16-2020, 02:58 PM #14Junior Member
- Aug 2018
- 13
Nice, seems like I just need to replaced that stator then Found them online for not to much money so I feel kind of lucky actually
Anyone have a dead, bricked or fried Mercury ECM ECU PCM555 for exploratory surgury.
By Findre in forum Technical DiscussionReplies: 7Last Post: 07-29-2019, 03:48 PM -
Merc Laser 220 w/ dead EFI pump - Walbro 255LPH ok?
By gmacrae in forum Technical DiscussionReplies: 6Last Post: 11-25-2013, 11:42 PM -
dead spot in throttle on mercury 200hp 2.5c
By mouse4x4 in forum Technical DiscussionReplies: 8Last Post: 10-21-2013, 08:22 PM -
Dead spot Mercury 200 XRI
By 205pro in forum Technical DiscussionReplies: 0Last Post: 08-13-2010, 12:42 PM -
vro (dead horse) 225 mercury
By huffdaddy in forum Technical DiscussionReplies: 3Last Post: 11-14-2002, 09:37 AM
