Results 1 to 15 of 26
    Copper fuel line?
    Anyone ever tried using COPPER line for fuel lines?
    I'm doing a Vst delete and thinking out of the box and modified a filter to accept 3/8"npt and 1/2" copper tubing.
    If I suport the tubing well will copper be ok to use?
    This pic is just a test to see if the pump and all routed. So far it pumps great
ID:	470761   Click image for larger version.
    Jul 2012
    Huntington, Texas
    I wouldn't. Copper doesn't like vibration at all. Nothing like fuel spraying around everywhere...
  3. Likes Capt.Insane-o liked this post
    Copper is a boat no,no. Even on steering systems it is sketchy.
  5. Likes nitro_rat liked this post
    Sep 2019
    madison wisconsin
    It won't hold up to the bouncing the lines will come loose in the compression fittings. Flares might do ok. Otherwise the new standard on semis is a nylonish tubing and compression fittings
    Juneau, WI
    Jeg's has stainless fuel line kits. https://www.jegs.com/p/JEGS/JEGS-Sta...51509/10002/-1
    Jun 2010
    Ont.Canada
    My CVX20 Carlson had copper line from the tank in the front(probably it's whole life)and never had an issue.
    If I knew it was going to last this long I would have taken better care of it.
    Chris
  9. Likes phillnjack liked this post
    Pekin, IL
    As hard as it is to believe they are using copper for brake lines now. I guess it all depends on the alloys used.
    Rock
    Team Junk
  11. Likes keefallan liked this post
  12. #8
    Juneau, WI
    Quote Originally Posted by rock View Post
    Rock
    Copper-Nickel alloy: https://oppositelock.kinja.com/the-t...nes-1818499200
  13. Likes CVX20SPRINT liked this post
  14. #9
    May 2016
    keys
    Thought I read or was told once about copper reacting with ethanol or other fuel additives. Anybody else ever heard this?
  15. #10
    Quote Originally Posted by Whaaaaat View Post
    ...nope...not me...
  16. #11
    ...this electric fuel pump(walbro) came standard with all johnrude V-8 outboards, as well as some of the V-6's, for years & years. copper tubing & fittings. hey, but that was omc...
  17. Likes keefallan liked this post
  18. #12
    Jul 2012
    Huntington, Texas
    That's a loop on a single part that is rubber isolated. The weight of the tubing is self supporting and I would agree that it's suitable for that application. Notice the connections to external components are hose barb...
  19. #13
    May 2016
    keys
    https://pubs.acs.org/doi/abs/10.1021/ef049849h
    Thought I was on to something.
    Bet that's why there's always the weird green goo on brass fittings in the fuel circuit. If so copper would produce far more than brass.
  20. #14
    ...i would not use copper tubing & fittings for fuel on a boat. i was just showing that omc used it at one time.
  21. #15
    I have seen lots of copper used on old diesel boats. It was always green and slimy. Never replaced any with new copper. Have used stainless tube for the straight runs and hose for bends.
  1. Replies: 7
    Last Post: 10-06-2019, 02:52 PM
  2. Mercury Tech: Fuel line, vacuum hose, and water line replacement
    By RHafley in forum Technical Discussion
    Last Post: 12-23-2017, 08:43 PM
  3. Fuel Line/Bleed Line Routing for '96 2.5 200EFI
    By Hydrasports205 in forum Technical Discussion
    Last Post: 09-11-2017, 11:08 PM
  4. Clogged Fuel Line??? Difficult to pull fuel through fuel line.
    By supervetteracer in forum Technical Discussion
    Last Post: 04-30-2016, 09:08 AM
