Results 1 to 15 of 43
Thread: Copper fuel line?
08-01-2020, 08:49 AM #1
Copper fuel line?
Anyone ever tried using COPPER line for fuel lines?
I'm doing a Vst delete and thinking out of the box and modified a filter to accept 3/8"npt and 1/2" copper tubing.
If I suport the tubing well will copper be ok to use?
This pic is just a test to see if the pump and all routed. So far it pumps great
08-01-2020, 09:52 AM #2
I wouldn't. Copper doesn't like vibration at all. Nothing like fuel spraying around everywhere...
Capt.Insane-o liked this post
08-01-2020, 09:54 AM #3Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
Copper is a boat no,no. Even on steering systems it is sketchy.
nitro_rat liked this post
08-01-2020, 09:55 AM #4Member
- Sep 2019
- madison wisconsin
- 31
- 10
It won't hold up to the bouncing the lines will come loose in the compression fittings. Flares might do ok. Otherwise the new standard on semis is a nylonish tubing and compression fittings
08-01-2020, 10:12 AM #5
Jeg's has stainless fuel line kits. https://www.jegs.com/p/JEGS/JEGS-Sta...51509/10002/-1
08-01-2020, 10:28 AM #6
My CVX20 Carlson had copper line from the tank in the front(probably it's whole life)and never had an issue.
If I knew it was going to last this long I would have taken better care of it.
Chris
phillnjack liked this post
08-01-2020, 10:39 AM #7
As hard as it is to believe they are using copper for brake lines now. I guess it all depends on the alloys used.
RockTeam Junk
keefallan liked this post
08-01-2020, 11:43 AM #8
Copper-Nickel alloy: https://oppositelock.kinja.com/the-t...nes-1818499200
CVX20SPRINT liked this post
08-01-2020, 12:18 PM #95000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
Thought I read or was told once about copper reacting with ethanol or other fuel additives. Anybody else ever heard this?
08-01-2020, 12:40 PM #10The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
08-01-2020, 12:46 PM #11The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...this electric fuel pump(walbro) came standard with all johnrude V-8 outboards, as well as some of the V-6's, for years & years. copper tubing & fittings. hey, but that was omc...
08-01-2020, 12:53 PM #12
08-01-2020, 03:42 PM #135000 RPM
- May 2016
- keys
- 795
- 31
- 45
- 254
- 424
https://pubs.acs.org/doi/abs/10.1021/ef049849h
Thought I was on to something.
Bet that's why there's always the weird green goo on brass fittings in the fuel circuit. If so copper would produce far more than brass.Last edited by Whaaaaat; 08-01-2020 at 03:52 PM.
08-01-2020, 03:59 PM #14The Historic Photo Master
- Jan 2004
- Florida
- 37,836
- 64
- 1667
- 337
- 19216
- 3 Post(s)
...i would not use copper tubing & fittings for fuel on a boat. i was just showing that omc used it at one time.
08-01-2020, 05:04 PM #15Screaming And Flying!
- 14,753
- 381
- 1302
- 5602
- 11031
I have seen lots of copper used on old diesel boats. It was always green and slimy. Never replaced any with new copper. Have used stainless tube for the straight runs and hose for bends.
Fuel line to fuel filter leak that's not making any sense. Is Trident Fuel Line good?
By Bumblebeeman in forum Technical DiscussionReplies: 7Last Post: 10-06-2019, 02:52 PM -
Mercury Tech: Fuel line, vacuum hose, and water line replacement
By RHafley in forum Technical DiscussionReplies: 1Last Post: 12-23-2017, 08:43 PM -
Fuel Line/Bleed Line Routing for '96 2.5 200EFI
By Hydrasports205 in forum Technical DiscussionReplies: 2Last Post: 09-11-2017, 11:08 PM -
Clogged Fuel Line??? Difficult to pull fuel through fuel line.
By supervetteracer in forum Technical DiscussionReplies: 13Last Post: 04-30-2016, 09:08 AM
