Results 1 to 11 of 11
Thread: Mercury 3 liter EFI experts???
07-31-2020, 10:17 AM #1Member
- Jun 2020
- Florida
- 59
- 9
- 31
- 16
I recently purchased a Merc 3l EFI "Offshore series" from 1996 I want to say. The oil injection was disconnected when we got it, and the mechanic had significant trouble getting the oil alarm to turn off without disabling all warning alarms (but eventually got it figured out).
Upon testing, the boat popped the boat (a 23 SeaCraft) onto a plane a couple times, but other times bogged down and couldn't get her on a plane. The diaphragm pump has been replaced as well as spark plugs, and still same issue. The mechanics are scratching their heads and have basically given up. They think that once you disable the oil injection on this motor, it screws with the computers, leading to our symptoms.
Are there any experts on this particular motor that could give input? Even better would be someone willing to drive to the Palm Beaches in Florida to take a look at it (and get paid of course!)
07-31-2020, 10:50 AM #2
Removal of oil injection has no effect on motor, that is as long as you are now premixing your oil. I've run my 1998 250 efi like this for years. The symptoms you have are the same as when one of the bobbins on stator starts to go. JMO
David - WI, Capt.Insane-o liked this post
07-31-2020, 04:25 PM #3Member
- Jun 2020
- Florida
- 59
- 9
- 31
- 16
Thanks for the reply! As a quick update, I just test-rode the boat myself for the first time. It seemed to me that the exhaust was only coming out of the hub, making the engine sound really quiet and anemic at lower speeds. When we tilted the motor up before gunning it, it finally planed out. No water/splash got anywhere near the powerhead (no matter how it was trimmed), so I have a theory that perhaps the exhaust is being pushed underwater causing enough back pressure to bog the engine down. I'm thinking when we tilted it up, it raised the exhaust enough such that it it could start planing, where speeds are fast enough to create a low pressure area behind the prop. Is this possible? Or do you think this was just a coincidence?
Edit: I'll add it's a 30" shaft, so that prop is REALLY deep in the waterLast edited by rdoaner; 07-31-2020 at 04:41 PM.
07-31-2020, 04:57 PM #4
Try a prop with less pitch. hf...
07-31-2020, 07:24 PM #5Member
- Jun 2020
- Florida
- 59
- 9
- 31
- 16
07-31-2020, 09:05 PM #65000 RPM
- Jun 2009
- Sacramento Ca
- 121
What prop is on there and how is it vented
What are the wot rpms when the trim is set maximum speeds
You need to find a mo better Mercury technician
Merc 2.5 liked this post
07-31-2020, 09:51 PM #7
Every boat is diffrent even the same 2 hulls. U cant take 1 person word for it and think u cant get any better setup cause that person said , your prop needs more ventilation or u need go down little in pitch. What r the wot rpm and mph and what pitch prop now?? Will b very helpful to know those #s
08-01-2020, 12:04 PM #8
The prop isnt sometimes gonna get you on plane and sometimes not. If its a prop issue it might need to be ventilated. But if its a symptom that comes and goes you're looking in the wrong place I bet. JMO
rdoaner liked this post
08-01-2020, 12:23 PM #95000 RPM
- Jun 2009
- Sacramento Ca
- 121
be be sure it is vented to achieve 3500 pulse rpm during hole shot.Pull the power head and clean the idle relief ports
Removing oil injection will cause a lot more carbon to form in the relief holes as well as ring grooves, I am not a fan of removal on fishing motors, I get it on race motors thoughLast edited by lpugh; 08-01-2020 at 03:51 PM.
08-02-2020, 03:40 PM #10Member
- Jun 2020
- Florida
- 59
- 9
- 31
- 16
08-22-2020, 05:05 PM #11Member
- Jun 2020
- Florida
- 59
- 9
- 31
- 16
Thought I'd give an update:
When the boat was finally delivered, I took off the cowling and noticed one of the spark plug wires was severed (my mechanics must've been blind?). On top of that, the throttle was mounted in such a way that it runs into the console before reaching full throttle. That combination is one that would make it difficult to plane a boat.
Well, two weeks ago I got the motor to Chaz, who not only knows his sh!t but really takes pride in his work. He has quite an impressive shop, as well as quite impressive attention to detail. He will be doing a complete restoration of the motor, as well as replacing the reed valves, drilling out the exhaust tube, and presumably sprinkling some of his magic into the motor.
When I talked with Chaz, he seemed interested in documenting the process for ScreamandFly (I hope I got that right Chaz... if not my apologies!). If so I know I will not be the only one interested in seeing the process
When she's all said and done, I will be updating with a video of her performing. Very excited to show this motor off... the 1995-1999 Merc Offshore EFI 3 liters are my favorite motors of all time
Need help with Mercury part # (Smartcraft experts)
By TraceF3 in forum Technical DiscussionReplies: 9Last Post: 11-26-2018, 09:45 AM -
Mercury experts. New SSR HD hub vs traditional solid HD hub
By xb03fs in forum General Boating DiscussionReplies: 5Last Post: 09-05-2016, 07:54 AM -
Mercury Tech: BRAIN EXPERTS NEEDED! Mercury 225X 2.5 liter Motorola PCM issue.
By tozlakes in forum Technical DiscussionReplies: 23Last Post: 09-01-2016, 12:47 AM -
ATTENTION: Mercury OB experts - a question
By croSSed in forum General Boating DiscussionReplies: 16Last Post: 02-01-2008, 09:18 AM
