Results 1 to 7 of 7
    Sep 2019
    madison wisconsin
    The sneeze that won't go away
    I am at a loss. I have a 1988 90hp 3 carb triple . New water pump thermostat and popet. Cleaned the carbs twice now first by hand second by ultrasonic cleaner. I have 120psi on all 3 holes . It will start and run pretty smooth and what not and after 2 to 3 min it will sneeze through the exhaust. So I pulled reed plates and they were all good replaced all intake gaskets and still same thing. The water flow seems like it almost pulses out the tel tale. Do I have a bad head gasket?
    Jan 2012
    coastal carolina
    try adjusting the idle air control , mine likes 1 1/2 turns out. I would lean towards a lean condition causing this. but I had a skip a couple of years ago and it ended up being a coil. check plugs to check head gasket but compression test should rule that out.
    Sep 2019
    madison wisconsin
    Ok so I played with it some more today and was able to get it up to temp on the muffs . got it about adjusted but now it idles nice but if I crack the throttle then let off it will cough . as I was watching for fuel to come out the front of the carbs I noticed exhaust would puff out of the fuel pump pulse line when it coughs so I stopped there
    May 2001
    Ga
    sounds like the carb butterflys are not synked together .hf...
    Jan 2012
    coastal carolina
    I would replace the line, sounds like it has a leak. then try it again. I picked up the bent line in o reilly's part store in the self help section. Had them cut me a piece of straight line, I replaced all of them at same time. take your line with u and match it up. I also got new fuel filter at advance
    Sep 2019
    madison wisconsin
    So if I zero out the butterfly I need to recheck timing then correct? How many degrees
    Sep 2019
    madison wisconsin
    So pulled plugs and set timing to 4deg while cranking . Re zeroed butterflys and set needles to 1.5 turns and fired right up runs good .
  1. OMC Lean Sneeze
    By Snickers89 in forum Technical Discussion
    Last Post: 06-18-2020, 05:35 PM
  2. 225 efi Sneeze and sludge
    By Seanj85 in forum Technical Discussion
    Last Post: 10-18-2019, 10:22 PM
  3. Sneeze at idle
    By Blown Up in forum Technical Discussion
    Last Post: 04-29-2013, 09:22 PM
  4. What is a lean sneeze
    By xb03fs in forum Technical Discussion
    Last Post: 10-29-2009, 03:18 PM
  5. Lean Sneeze on Pro Max 300
    By 22VelocityProMax300 in forum Technical Discussion
    Last Post: 06-26-2001, 06:48 PM
