Results 1 to 7 of 7
Thread: The sneeze that won't go away
07-30-2020, 08:17 PM #1Member
- Sep 2019
- madison wisconsin
- 31
- 10
I am at a loss. I have a 1988 90hp 3 carb triple . New water pump thermostat and popet. Cleaned the carbs twice now first by hand second by ultrasonic cleaner. I have 120psi on all 3 holes . It will start and run pretty smooth and what not and after 2 to 3 min it will sneeze through the exhaust. So I pulled reed plates and they were all good replaced all intake gaskets and still same thing. The water flow seems like it almost pulses out the tel tale. Do I have a bad head gasket?
07-31-2020, 12:32 AM #2Junior Member
- Jan 2012
- coastal carolina
- 13
try adjusting the idle air control , mine likes 1 1/2 turns out. I would lean towards a lean condition causing this. but I had a skip a couple of years ago and it ended up being a coil. check plugs to check head gasket but compression test should rule that out.
07-31-2020, 03:30 PM #3Member
- Sep 2019
- madison wisconsin
- 31
- 10
Ok so I played with it some more today and was able to get it up to temp on the muffs . got it about adjusted but now it idles nice but if I crack the throttle then let off it will cough . as I was watching for fuel to come out the front of the carbs I noticed exhaust would puff out of the fuel pump pulse line when it coughs so I stopped there
07-31-2020, 04:59 PM #4
sounds like the carb butterflys are not synked together .hf...
07-31-2020, 05:43 PM #5Junior Member
- Jan 2012
- coastal carolina
- 13
I would replace the line, sounds like it has a leak. then try it again. I picked up the bent line in o reilly's part store in the self help section. Had them cut me a piece of straight line, I replaced all of them at same time. take your line with u and match it up. I also got new fuel filter at advance
07-31-2020, 06:04 PM #6Member
- Sep 2019
- madison wisconsin
- 31
- 10
So if I zero out the butterfly I need to recheck timing then correct? How many degrees
08-02-2020, 12:53 PM #7Member
- Sep 2019
- madison wisconsin
- 31
- 10
So pulled plugs and set timing to 4deg while cranking . Re zeroed butterflys and set needles to 1.5 turns and fired right up runs good .
OMC Lean Sneeze
By Snickers89 in forum Technical DiscussionReplies: 8Last Post: 06-18-2020, 05:35 PM -
225 efi Sneeze and sludge
By Seanj85 in forum Technical DiscussionReplies: 20Last Post: 10-18-2019, 10:22 PM -
Sneeze at idle
By Blown Up in forum Technical DiscussionReplies: 5Last Post: 04-29-2013, 09:22 PM -
What is a lean sneeze
By xb03fs in forum Technical DiscussionReplies: 3Last Post: 10-29-2009, 03:18 PM -
Lean Sneeze on Pro Max 300
By 22VelocityProMax300 in forum Technical DiscussionReplies: 4Last Post: 06-26-2001, 06:48 PM
