Results 16 to 28 of 28
Thread: Outboard Ignition System
08-02-2020, 08:35 AM #165000 RPM
- Nov 2003
- California
- 191
- 49
- 66
- 29
Pan Ronnie...... Thanks for the input. The attached thumbnail was a great help. It looks like the IGNIA coils will be more the adequate. It's a lake ski motor and is all over before 7K. Your suggestion about logging existing program is good. I was running a Simple Digital System controlling the fuel side only. Patch fire.... no drivability, on or off only. Not much to down load. I now have a new link extreme ecu in the box and hoping. It's a 3.0 looper warm not hot running on pump gas. Any suggestions or direction help would be greatly appreciated.
08-02-2020, 08:42 AM #17Screaming And Flying!
- Jun 2007
- Singapore/Melbourne/Italy
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
08-02-2020, 09:41 AM #18
if you want to educate yourself about coil dwell this is a nice site
http://dtec.net.au/Ignition%20Coil%2...alibration.htm
it also shows that the biggest isn,t always best
with the Medium Energie Coils MEC you can achieve much shorter coil dwell times
skiboater, powerabout thanked for this post
08-03-2020, 09:04 AM #19Screaming And Flying!
- Jun 2007
- 9,109
- 1010
- 356
- 4327
- 1976
- 8 Post(s)
08-03-2020, 09:12 AM #20
08-03-2020, 09:53 AM #21
Most of the standalone ECU's on the market these days can fire the coils, it's only the dumb coil (inductive) that would require an ignitier. If you do plan on eventually modding the engine more to turn higher rpm's it's best to go CDI that way you will have the system already but if $$$$ is an issue then run the IGN1A coils until & if you decide to go that route.
skiboater liked this post
08-03-2020, 10:07 AM #22
Most of the outboard guy's I know that run EFI on the slO-MC run CDI ignition for racing, lake use they can use IGN1A coils once your not running high rpm. I remember back when Wayne Taylor was starting to use the Wolf Ecu & using those coils they were failing a lot because they were being ran at high rpm. I know on a 4-stroke they can & will turn over 9000 rpm probably due to them firing once during a 720* cycle on the 4-stroke but on the 2-stroke it has to fire twice in the same amount of degrees so it does have a little more time to cool down on the 4-stroke vs the 2-stroke.
08-03-2020, 10:09 AM #23
Cool, says alot for the honeywell gt101 too... Chart shows why its nice to go 14 or 16V...To play with dwell times and duty cycles go to gtsparkplugs.com they have a nice calculator to play with to see what the duty cycle will beat any given dwell and rpm. CdI takes all the guess work out...
08-03-2020, 10:14 AM #24
Hey Dave how's the tuning coming on your rig? How you finding the Emtron? I've been looking at getting a KV12 for a project as well.
08-03-2020, 10:37 AM #25
Really havent run it too much after all the work,all the ramps were closed here for 2 months here then were a disaster when they opened, now so many people off work we have mandatory ot so the boats been parked for a while.. The emtron is amazing but im still learning, I think they expect you to be on a team level already of which im not so theres alot of wtf and then oh thats easy. It has so many features that i will never get into but you never know lol..
08-03-2020, 11:00 AM #265000 RPM
- Nov 2003
- California
- 191
- 49
- 66
- 29
Hitman.... Makes sense, pay me now or pay me later. Any recommendations on igniters?
08-03-2020, 01:18 PM #27
08-03-2020, 01:22 PM #28
Ignition system
By sicknick12 in forum Technical DiscussionReplies: 3Last Post: 08-08-2016, 02:59 PM -
MSD Ignition system
By Doran59 in forum Technical DiscussionReplies: 1Last Post: 08-25-2008, 06:39 PM -
OMC Ignition System
By imq707s in forum Electronics, Audio Systems, and WiringReplies: 0Last Post: 07-02-2004, 03:43 PM
