Page 2 of 2 FirstFirst 1 2
Results 16 to 28 of 28
    Nov 2003
    Pan Ronnie...... Thanks for the input. The attached thumbnail was a great help. It looks like the IGNIA coils will be more the adequate. It's a lake ski motor and is all over before 7K. Your suggestion about logging existing program is good. I was running a Simple Digital System controlling the fuel side only. Patch fire.... no drivability, on or off only. Not much to down load. I now have a new link extreme ecu in the box and hoping. It's a 3.0 looper warm not hot running on pump gas. Any suggestions or direction help would be greatly appreciated.
  2. #17
    8 Post(s)
    Quote Originally Posted by skiboater View Post
    My experience is when you ask the maker of those coils and ignition systems if they will run over 7 they all say probably not and will overheat.
    Can you get a Merc 280 system to run over 9k?
  3. #18
    Jan 2003
    aalsmeer
    if you want to educate yourself about coil dwell this is a nice site
    http://dtec.net.au/Ignition%20Coil%2...alibration.htm
    it also shows that the biggest isn,t always best
    with the Medium Energie Coils MEC you can achieve much shorter coil dwell times
  4. Thanks skiboater, powerabout thanked for this post
  5. #19
    8 Post(s)
    Quote Originally Posted by PanRonnie View Post
    at 10000 rpm a crank rotation is 6 Miliseconds
    with a coil dwell of 3 miliseconds and spark duration of 1 milisecond you still have 2 miliseconds of down time
    now it maybe not much but unless you scream and fly all day long you can still use the IGN1A coils
    3 miliseconds is enough to burn off 2 stroke oil of the sparkplug
    if you are very rich on oil then it would be time to start looking at CD ignition
    but you can still experiment with longer dwell settings
    Hi Pan
    Next question is can your ecu run at enough hz to run the ignition at high speed?
  6. #20
    Jan 2003
    aalsmeer
  7. Thanks skiboater thanked for this post
    Likes mrichartz, H2OPERF, skiboater liked this post
  8. #21
    Watching you!
    Most of the standalone ECU's on the market these days can fire the coils, it's only the dumb coil (inductive) that would require an ignitier. If you do plan on eventually modding the engine more to turn higher rpm's it's best to go CDI that way you will have the system already but if $$$$ is an issue then run the IGN1A coils until & if you decide to go that route.
    HITMAN 8,500 good to know. What are you firing the smart coils with?
  9. Likes skiboater liked this post
  10. #22
    Watching you!
    Most of the outboard guy's I know that run EFI on the slO-MC run CDI ignition for racing, lake use they can use IGN1A coils once your not running high rpm. I remember back when Wayne Taylor was starting to use the Wolf Ecu & using those coils they were failing a lot because they were being ran at high rpm. I know on a 4-stroke they can & will turn over 9000 rpm probably due to them firing once during a 720* cycle on the 4-stroke but on the 2-stroke it has to fire twice in the same amount of degrees so it does have a little more time to cool down on the 4-stroke vs the 2-stroke.
  11. Likes skiboater liked this post
  12. #23
    MIAMI FLORIDA
    Cool, says alot for the honeywell gt101 too... Chart shows why its nice to go 14 or 16V...To play with dwell times and duty cycles go to gtsparkplugs.com they have a nice calculator to play with to see what the duty cycle will beat any given dwell and rpm. CdI takes all the guess work out...
  13. Likes "HITMAN", skiboater liked this post
  14. #24
    Watching you!
    Hey Dave how's the tuning coming on your rig? How you finding the Emtron? I've been looking at getting a KV12 for a project as well.
  15. #25
    MIAMI FLORIDA
    Really havent run it too much after all the work,all the ramps were closed here for 2 months here then were a disaster when they opened, now so many people off work we have mandatory ot so the boats been parked for a while.. The emtron is amazing but im still learning, I think they expect you to be on a team level already of which im not so theres alot of wtf and then oh thats easy. It has so many features that i will never get into but you never know lol..
  16. #26
    Nov 2003
    Hitman.... Makes sense, pay me now or pay me later. Any recommendations on igniters?
  17. #27
    Watching you!
    The IGN1A coils have the igniter built in so no need to run an external one
  18. #28
    Watching you!
    Keep us posted been waiting to find out how it run's. Stay safe.
    Quote Originally Posted by H2OPERF View Post
  1. Ignition system
    By sicknick12 in forum Technical Discussion
    Last Post: 08-08-2016, 02:59 PM
  2. MSD Ignition system
    By Doran59 in forum Technical Discussion
    Last Post: 08-25-2008, 06:39 PM
  3. OMC Ignition System
    By imq707s in forum Electronics, Audio Systems, and Wiring
    Last Post: 07-02-2004, 03:43 PM
