Results 1 to 1 of 1
Thread: metal working equipment for sale
07-29-2020, 11:18 PM #1Guest
- LINDENHURST, NY
- 119
COIL CAR BRANER 48 X 20000 LB CAPACITY $8000
COIL CAR 20000 LB CAP 36 BED WAS USED ON A 72 WIDE INSPECTION LINE $8000
COIL CAR 30000 LB CAP 32 BED $10000
COIL TRANSFER CAR COILTECH 36 WIDE 20000 LB CAPACITY $5000
COIL UPENDER COIL CART COMBINATION BRANER 48 X 20000 LB CAPACITY $20000
COIL UPENDER WEST BEND 6000 LB CAPACITY 42 X 42 Base $5500
CUT TO LENGTH
JORG 15 INCH CUT TO LENGTH 14 GAUGE CAPACITY 2000 LB COILS $7500
28 WIDE HALLDEN SYCHRONIZED GULLIOTENE SHEAR 14 GAUGE CAPACITY $15000
60 WIDE IOWA PRECISION CUT TO LENGTH LINE 12 GAUGE CAPACITY 20000 LB COILS $55000
72 WIDE MCKAY CUT TO LENGTH LINE ¼ INCH CAPACITY 300000 LB COILS $90000
72WYSONG SHEAR 5/16 CAP FROM A ROWE CUT TO LENGTH LINE $15000
DOWNLAYER 58 X 66 7000 LB CAPACITY $5500 11 INCH ID 24 INCH EXTENSION ON DOWNLAYER
DOWNLAYER & PACKAGING LINE FOR SLITTING LINE 5000 LB CAPACITY $8000
ENTRY & EXIT TABLES
FORTE ENTRY TABLE 12 GAUGE CAP 60 WIDE S/N 104 $2500
PAXSON PEELER TABLE 50 WIDE DUAL HYD CYLINDERS 3/8 CAPACITY $2500
ROWE ENTRY TABLE FOR 60 WIDE COIL $1500
FLATTNER/STRAIGHTNER
BENCH MASTER 10 INCH WIDE FLATTNER MODEL #910FSDC 440 3 PHASE MOTOR 2 AMPS 1 HP SERIAL # 29643 $500
BENCH MASTER 5 INCH WIDE FLATTNER MODEL #910FSDC 440 3 PHASE MOTOR 2 AMPS 1 HP SERIAL # 29661 $500
FLATTNER 15 WIDE 16 GAUGE CAPACITY $500
COOPER WEYMOUTH 10 INCH STRAIGHTNER $1500
RED BUD 18 INCH STRAIGHTNER 020-125 CAPACITY $2500
GARY 60 WIDE STRAIGHTNER $7500
FORKLIFTS
8000 LB CAT PROPANE 72 INCH FORKS SOLID TIRES $6000
10000 LB ALLIS CHALMERS SOLID TIRE $4500
14000 LB ALLIS CHALMER SOLID TIRE PROPANE SIDE SHIFT $12000
16500 LB YALE PROPANE SOLID TIRE RIGGERS SPECIAL1968 YALE SN AK144067 MODEL G-5 165MAS $15000 Florida
20000 LB YALE PROPANE SOLID TIRES RIGGERS SPECIAL 1978 $20000
20000 LB YALE PROPANE SOLID TIRES RIGGERS SPECIAL $18000
30000 LB Autolift forklift w/rotating forks (BRUDI ROTATOR) 7047 hrs year 1989 diesel eng. serial B-1340 model D5-300-OC $18000
40000 LB SILENT HOIST PROPANE SOLID TIRE RIGGERS SPECIAL $18000
GAUER EDGERS 4 AVAILABLE
6 INCH GAUER EDGER COIL TO COIL # 5 DEBURRED EDGE 2500 LB COIL CAPACITY $10000
5H 40 GAUER DEBURRING MACHINE $1500 5H 40 GAUER DEBURRING MACHINE $1500
5H 40 GAUER DEBURRING MACHINE $1500 5H 10 GAUER DEBURRING MACHINE $1500
7 INCH EDGER $1500
GUILD WELDER
GUILD WELDER Model DMA-100-3 $5000
PVC/PAPER APPLICATOR
48 WIDE PVC/PAPER APPLICATOR $2000
RECOILERS
RECOILER 6 WIDE 5000 LB CAPACITY 10 HP DRIVE 16 ID OVERARM SEPERATOR $4500
RECOILER 15 WIDE 5000 LB CAPACITY OVER ARM SEPERATOR 16 ID DRUM GEAR BOX NO MOTOR $3500
RECOILER 36 WIDE YODER 10000 LB CAPACITY 16 ID OVER ARM SEPERATOR HYD PUSH OFF $10000
GARY 48 WIDE RECOILER 10000 LB CAPACITY 40 HP HYDRAULIC EXPANSION 20 ID DRUM PUSH OFF MODEL 4910 SP 48 S/N 251 $10000
WEAN RECOILER 72 WIDE 20000 LB COILS PUSH OFF 24 ID 20 HP MOTOR $15000
PROGRESSIVE RECOILER 72 WIDE 30000 LB CAPACITY 100 HP DRIVE OVERARM SEPERATOR
PUSH OFF 20 ID MANDREL HYRAULIC EXPANSION $60000
RECOILER DRUMS
4000 LB CAPACITY 18 WIDE X 2.937 ID X 16 INCH DIAMETER WITH 20 ID FILL PLATES $1500
4000 LB CAPACITY 18 WIDE X 2.937 ID X 8 INCH DIAMETER $1250
20000 LB CAPACITY 54 WIDE X 7.450 ID X 22 INCH DIAMETER $1500
40000 LB CAPACITY 82 WIDE X 12.062 ID X 16 INCH DIAMETER $2500
40000 LB CAPACITY 82 WIDE X 12.062 ID X 18 INCH DIAMETER $2500
40000 LB CAPACITY 82 WIDE X 12.062 ID X 24 INCH DIAMETER $2500
SCRAP WINDERS
SCRAP WINDER DUAL REELS NEED SOME WORK BEARING BLOCK NEEDS SOME BOLTS /CHAINS/1 HYD MOTOR ALL HYRAULIC $4000
SCRAP WINDER GARY $4000
SCRAP WINDER IOWA PRECISION $4000
SCRAP WINDER PROGRESSIVE HYD AUTOMATIC DISCHARGE FROM REAR $15000
SHEARS
12 INCH RED BUD SHEAR 020-062 CAPACITY $2500
50 IN JORG SHEAR 14 GAUGE $4000
72 IN WYSONG SHEAR FROM CUT TO LENGTH LINE CUTS 5/16 $15000
SLITTER HEADS
18 TORRINGTON SLITTER HEAD 2 5/8 arbors $2500
24 YODER SLITTER HEAD 41/2 ARBORS $2500
36 YODER SLITTER HEADS 6 ARBORS 2 AVAILABLE $7500 EACH
36 P & M SLITTER HEAD 6 ARBORS $7500
48 COIL TECH 7 ARBOR SLITTER HEAD SLIDES IN TO 36 $20000
60 WIDE YODER SLITTER HEAD 5 ARBORS $12000
72 WIDE UNIVERSAL SLITTER HEAD 100 HP DRIVE COMPLETE WITH TOOLING 7 ARBORS $45000
SLITTING LINES
18 YODER SLITTING LINE 2 ½ ARBORS VARIABLE SPEED DRIVE 6 8 10 16 ID ARBORS 2500 LB RECOILER 5000 LB UNCOILER $30000 COMPLETE WITH TOOLING
18 RUESCH REPLICA RING SLITTER 2 7/8 ARBORS NEEDS TOOLING 2500 LB COIL CAPACITY RECOILER HAS A 6 ID & 8 ID WITH HYD PUSH OFF ASEA 15 Hp ON SLITTER ARM 550 150/300V TYPE 180 FRAME 284A $15000
18 INCH STANAT SLITTING LINE 2 ½ ABORS 2500 LB COILS $70000
18 INCH STANAT SLITTING LINE 3 ARBORS 5000 LB UNCOILER 5000 LB RECOILER $70000
24 INCH STANAT SLITTING LINE 3 ARBORS 5000 LB COILS 8 12 16 20 ID ON RECOILER $60000 Florida
24 YODER SLITTING LINE 2 ½ ARBORS 1500 LB COILS $60000
30 STANAT SLITTING LINE 5 ARBORS SLITTER HEAD CLOSES TO 12 INCHES WIDE 10000 LB COILS $125000
36'' X 4'' YODER MDL. 4E36 SLITTING LINE, 10,000# COILS, 38'' UNTRIMMED COIL WIDTH, 36'' TRIMMED COIL WIDTH, RIGHT TO LEFT MATERIAL FEED, SLIDING BASE WATER COOLED BRAKE ON UNCOILER, OUTBOUND HOUSING ON SLITTER HEAD, SINGLE ARM TURNTILE WITH PUSHOFF., SCRAP WINDERS, OVERARM SEPARATOR, EUROTHERM DC DRIVES $45000
36 YODER SLITTING LINE 2 HEADS 6 ARBORS 10000 LB 36 WIDE YODER UNCOILER 36 YODER RECOILER 16 ID NEEDS TOOLING & SCRAP WINDER $25000
36 BRANER SLITTING LINE 5 ARBORS 15000 LB CAPACITY $125000
48 YODER SLITTING LINE 5 ARBORS 48 GARY RECOILER 20 ID HYD EXP 10000 LB CAP STAMCO 15000 LB UNCOILER NEEDS TOOLING & SCRAP WINDER $30000
72 PROGRESSIVE/BRADBURY/UNIVERSAL SLITTING LINE 7 ARBORS 20000 LB CAPACITY $125000
TENSION STANDS
72 INCH DRAG BOARD TENSION STAND $7500
TURNSTYLE
2 ARM 60 X 20000 LB CAPACITY $10000
TRAVERSE WINDER
stanat traverse winder model HTR 14 1500 Hydraulic S/N 12897 Needs Some Parts $5000
UNCOILERS
12 INCH REGAL UNCOILER 3000 LB CAPACITY $2500
15 INCH UNCOILER 2500 LB COIL CAPACITY $2000
18 INCH WIDE 2500 LB CAPACITY 16-20 EXP COOPER WEYMOUTHELECTRIC BRAKE $2000
18 INCH WIDE 5000 LB CAPACITY 16-20 EXP COOPER WEYMOUTH WITCHITA AIR BRAKE $5000
18 INCH WIDE 5000 LB CAPACITY 12-16 EXPANSION $4000
24 INCH WIDE 10000 LB CAPACITY 16 -20 MANUAL EXPANSION COOPER WEYMOUTH WITCHITA AIR BRAKE $7500
24 INCH WIDE 6000 LB CAPACITY 16-20 EXPANSION COLT AUTOMATION $5000
24 INCH WIDE 6000 LB CAPACITY DURANT 15-20 EXPANSION $5000
24 INCH WIDE 7500 LB CAPACITY 16-20 EXP P & M Sliding Base $6000
24 INCH WIDE 7500 LB CAPACITY DUAL ARM 1 arm needs repair $6000
28 INCH WIDE 7500 LB CAPACITY DUAL ARM $8000 Florida
36 INCH YODER UNCOILER 10000 LB CAPACITY 16-20 MANUAL EXPANSION $6000
36 INCH DAHLSTROM UNCOILER 15000 LB CAPACITY 21-24 HYD EXPANSION $10000
40 INCH LITTELL 6000 LB UNCOILER ELECTRIC BRAKE 14 TO 16 MANUAL EXPANSION $5000
48 INCH STAMCO UNCOILER 15000 LB CAPACITY 20 -24 ID HYD EXPANSION SLIDING BASE FEED UP MOTOR $10000
60 WIDE UNCOILER AIR BRAKE 20-24 HYD EXP 20000 LB CAPACITY $10000
72 BRADBURY 20000 LB UNCOILER WITH COIL CAR 20-24 ID FEED UP DRIVE HOLD DOWN AIR BRAKE $45000
UNCOILER DRUM
30000 LB CAPACITY 62 WIDE X 9500 ID X 18 DIAMETER $2500
USED SLITTER KNIVES FOR SALE
PIECES OUTSIDE DIA. INSIDE DIA. KEYWAY THICKNESS PRICE
52 9.500 4.000 .750 X .375 .375 $100 EA.
33 11.350 6.000 .187 $150 EA. 27 10.985 6.000 .375 $150 EA. 36 10.730 6.000 .375 $150 EA. 50 10.565 6.000 .375 $150 EA.
HARDINGE LATHE NO TOOLING $500
BUDGIT 1/2 TON HOIST $550 110 VOLT
BUDGIT 1/4 TON HOIST $450 110 VOLT
C & M 1 TON HOIST $750
YALE 1 TON HOIST $750 110 volts
BUDGIT 2 TON HOIST $1500
C& M 2 TON HOIST $1500
DUFF NORTON 2 TON HOIST $1500
DUFF NORTON 2 TON HOIST WITH TRACK MOTORS $2000
HARRINGTON 5 TON HOIST $2000
20000 LB DIGITAL CRANE SCALE $1500
spanco half ton jib crane with hoist 10 ft 6 high 9 ft reach
1 TON JIB CRANE WITH HOIST $3500
5000 LB HYDRAULIC JIB CRANE 11 FT REACH $3500
ACCO MANSAVER SHEET LIFTER 10000 LB CAPACITY 6 FT WIDE X 9 FT LONG $1500
CALDWELL 6000 LB C HOOK 12 WIDE X 21 MODEL NO 82NC-3-20 SERIAL NO 59270-1 WEIGHT 70 LBS PRICE $1000
DIXON 7000 LB C HOOK 24 WIDE X 25 LONG MODEL NO H-7--24-15 SERIAL # 26130 WEIGHT 125 LBS PRICE $1000
DIXON 2000 LB C-HOOK $750
FORKLIFT C HOOK 10000 LB $1000 WEIGHS 1900 LBS DEPTH 24 INCH WIDTH 30 INCH
SHORT STUBBY C HOOK 7500 LB $750 WEIGHS 1100 LBS DEPTH 24 WIDTH 48 INCH
NIBBLERS & SHEARS GAUGE RANGE FROM 020-187 THICKNESS CAPACITY PRICE $400-$950
BRAND NAMES AVAILABLE BLACK & DECKER -STANLEY- TRUMPF-BOSCH
CALL MIKE AT ACCURATE FOR ALL YOUR USED EQUIPMENT REQUIREMENTS!
PHONE 516-859-0039 EMAIL michael@accuratemetal.biz
website www.accuratemachinerymetalimportexport.us
Metal working equipment for sale
By MIKE in forum Misc. Parts and AccessoriesReplies: 0Last Post: 07-22-2020, 09:20 PM -
sheet metal and welding equipment
By rock in forum Non-Marine ItemsReplies: 3Last Post: 08-15-2018, 07:33 AM -
Ladd's SST120 equipment for sale
By race4kaos01 in forum Racer's HangoutReplies: 1Last Post: 05-28-2008, 05:39 PM
